Question about Samsung Quiet Jet 9068 Bagged Canister Vacuum
I sucked up a dusing cloth with my ducted vacuum cleaner and now it does not **** at all. Help can not afford a three hundred dollar bill.
    Problem Solver:
Turn off the power on the main vacuum unit. Then thread a plumber's snake or stiff small gauge wire from the outlet you were plugged into when the dust cloth got sucked up. With any luck, you'll be able to push it through a bit or with a small bend at the tip of the wire, you might catch hold of the rag and pull it out. You could also try sucking out the line with a shop vac by fitting it tightly into the outlet and turning on the vacuum.
Posted on Jan 01, 2009
  • 706 Answers
Please elaborate on the problem in detail.. Your vacuum sucked up a 'dusting cloth" ? Your description of a 'ducted vacuum' implies it is a central vac system ...is that true? If not please explain what you are using? The more details the more likely I can help...
Posted on Sep 14, 2008
How much do I need to spent to get a quality vacuum?
Cost isn't the main factor to get a quality vacuum. There are plenty of vacuums in all price ranges that may work great the first year or two. Some expensive vacuums have problems and require lots of maintenance. Most vacuums in the hundred dollar price range are good for about a year. Bagless vacuums require a lot more maintenance than a bagged vacuum. Filters must be cleaned frequently to insure good airflow, and the filters and belts should be replaced at least once per year on most models. Filter replacement on bagged vacuums is not as critical because the dirt goes into the bag keeping the insides of the vacuum a lot cleaner which makes it last longer. Some vacuums, Hoover Windtunnel for example are available as a bagged or bagless model. The bagged models perform much longer than the bagless models for the average consumer, mainly because most people do not maintain their vacuums properly. There are a few really great vacuums in the two to three hundred dollar range that can work great for 10 years or more with nominal routine maintenance. The best place to find one is at a reputable vacuum store.
Mar 07, 2017 | Vacuums
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Reset button ON DC25I
Dyson created a good vacuum cleaner but it seems odd that this problem of sucking a shoelace would disable your vacuum cleaner. I even replaced the head. PLUS they want 150 dollars to fix. Come on, if this where Dyson is going, to create something that's going to cost 100's of dollars to fix, then DO NOT BUY DYSON! They did send me a new head but my head still won't turn even after resetting the electrical button. I BET it's an easy fix. Lucky all we have is hardwood floors but frankly it would be hard for me to suggest to someone else that Dyson is the best. A product is ONLY as good as the warranty behind the product.
Apr 25, 2013 | Dyson DC25 All Floors Bagless Upright...
Belt removal
take case of make sure unplugged for 12 hour its behind front sucking duct
Nov 15, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I sucked up a dusing cloth with my ducted vacuum cleaner and now it does not **** at all. Help can not afford a three hundred dollar bill. blocked
hope it helps.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | Emerson Vacuums
Hoover steam cleaner F5912-900 not sucking up water
Check to make sure that the lid locked down all of the way around. If yours has a foam filter on the inside of the recovery tank lid, make sure it has at least a 1/4 in. gap from the top. There is a filter, from the bottom, has a red casing, remove it and clean it. Also make sure that the removeable duct in front of the recovery tank is in place.
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvan cleaner F5807
If this has a duct part #38661003 (#3) that is supposed to be installed in front of the tank isn't there, then you will have no suction to pick up the dirty water.
If this doesn't use a duct, then either the foam filter (#2) is up all of the way, need to leave 1/4 in. gap from the top, or the rear of the tank lid is not locked down.
Jan 22, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Samsung Quiet Jet 9068 Bagged Canister Vacuum Logo
111 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
Dyson Solutions...
Dyson Solutions...
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
