Question about Nokia 3650
System error of memory card
When i install the smart launcher application, i accidentally closed the applicaion when i press and hold the menu key. then my cellphone failed to function. i cant open any application, i cant even create a text message. when i press the menu key, i cant open any application and it just says there "system application". please help me.
    Problem Solver:
  • 7 Answers
Try to format your memory card, your phone can use without your memory card or simply replace your memory card........
Posted on Dec 05, 2007
  • 3 Answers
I had a 3650 and I get this error often. What I do is visit the celfone shops and have the operating system reinstalled. There's not much you can do on your part as every button you press leads to the system application error.
Posted on Oct 13, 2006
SOURCE:
How do i get my blu 5.5 to stop saying application error it wont let me do anything
This usually happens when moving apps to the SD Card with the stock Launcher (i.e., through the "Manage Aapplications" menu).
1. Remove the battery.
2. Remove the SD card.
3. Reset it to factory.
4. Install Launcher Pro & Launcher Switcher.
5. Reinstall the apps that you had.
6. Use Launcher Pro as your main launcher
Feb 26, 2015 | Televison & Video
Tip
HOW TO FREE MORE RAM ON YOUR S60 MOBILE
<p><b><span style="font-weight: bold;">How to free more RAM on your phone&gt;</span><br /></b><br /> <p><b>Method 1: Flight mode:</b><br /> <p>Put your phone in "Flight mode" with Psiloc System Tools. Install System Tools, open it and select "Flight mode". This way you can restart the phone without your SIM card so there will be no running phone tasks in the background. Now you can have up to 3,5 MB of free RAM!<br /> <p>Note: ironically enough, Flight mode doesn't work when Smart Launcher is installed, at least in my case.<br /> But i've also heard several reports of people who have both apps running without any problems.<br /> <br /> <p><b>Method 2: Smart Launcher trick:</b><br /> <p>Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON.<br />Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold).<br /> The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM).<br /> <p>The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when<br />the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when<br />you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so<br /> you trick the phone and you have more free RAM!<br /> Note: when you unplug the charger, the phone will switch off.<br /> <p><b>Method 3:<br /></b><br /> <p>It frees a little about 100~200 KB but I guess it's useful sometime. Close your menu not by selecting the right selection key "exit", or pressing the menu key another time, they only hide the menu app but do not close it, to close it select the left selection key "option" and scroll down and select "exit"<br /> <p>So when you open an app needs more ram reopen menu and close it, it's useful when play low bit rate video in realplayer paradis.<br /> <br /><br />
on Mar 04, 2011 | Cell Phones
Frozen. If we press any app the same error message
Press and hold Menu button to go into Search. Search for app Settings and launch it. Go to Applications, Manage Applications, All and select TwLauncher. Go to Storage -> Clear data. No more force close loop. TwLauncher sets back yo default. You'll need to customize/add back your launcher 'desktop' again.
Mar 10, 2013 | Cell Phones
The Application HTC Sense (process com.htc.launcher) has stopped unexpectedly
This is the main OS force closing itself, if you can do it the only way to resolve is a master reset. You can do this by:
  1. Power handset 'Off'.
  2. Remove the Data Card, if applicable.
  3. Press and hold Back and Home keys.
  4. While still holding Back and Home keys, press power button.
  5. Click the MENU key to reset.
Feb 10, 2011 | HTC Hero Smartphone
I can't sending text msg from my phone....when i send i get error :-general memory full..closed some application and try again.. and i also forget my lock code so i can;t restore factory...
its a common problem, the phone memory gets filled up quickly, 1st you have to format the phone memory then this problem can be solved but make sure to change the message storage memory to memory card instead of phone memory, otherwise this problem will occur again.
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
rate my answer too
Jan 11, 2011 | Nokia N81
I have sony vaio but the av mode is not working and i have VGN-CS215J
Hi.
According to the information online, the issue might be due to the VAIO Launcher Application.
The VAIO Launcher Application is responsible for the functionality of the AV Mode keys.
Hence, it would be better to re-install the VAIO Launcher Application.
It is also recommended to install the Sony Shared Library before installing the VAIO Launcher Application.
I have mentioned all the links from which you can download the Sony Shared Library and the VAIO Launcher Application:
Sony Shared Library:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4236&os_id=34
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4403&os_id=34
Please click on the above links to download the Sony Shared Library and the VAIO Launcher Application.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 17, 2010 | Sony VAIO VGN-CS215J/W Notebook
Pre Cell Phone: how do i remove an application from my launcher?...
Press and hold the red key on your key pad. Tap the ap and delete. Only the applications you installed can be removed.
May 17, 2010 | Palm Pre Cell Phone
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Oct 30, 2009 | Nokia N97 Cell Phone
Can't run applications from an expansion card
In some cases, applications developed before Palm OS® 4.0 that are loaded to an expansion card may encounter errors when launched. However, these applications generally run properly when installed directly to your handheld's internal memory. Here's how to do that: 1. Access the Applications launcher. 2. Open the Menus. 3. From the App menu, select Copy. 4. In the Copy To: pulldown menu at the top of the screen, select your expansion card. 5. In the list of applications, locate the file you want to copy to your handheld's internal memory. Highlight the file. 6. At the bottom of the screen, select Copy. Then select Done. 7. Go back to the Applications launcher. At the top right of the screen, there's a pulldown menu with different application categories. Choose All (this is a category that's on your handheld, not on your expansion card). 8. Locate the application you copied, and launch it from this screen. 9. Contact the developer of the application for more information on application compatibility with expansion cards.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Nokia 3650 Logo
101 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
