Question about Optoma HD72 Multimedia Projector
Low brighness I used my projector for 300 hrs. Now the pictures are comming dim i have adjusted the brightness and contrast but there is no result.
  • Anonymous Dec 03, 2008
    picture is very dim and bulb counter is only at 180 hrs. Do I need to replace bulb?
  • 431 Answers
This sounds more like a Lcd fault than bulb after such a short time after bulb replacement ,however I did have this come up once and the customer had kept his unit in a cold place then took it out to use hence due to the heat from the lamp Condensation dulled the mirrors .After they warmed up all was ok untill the next time solution I told him to store it somewhere warm .. havent heard from him since except for his stereo repair , and you don't want to know what the fur substance in that turned out to be lol
if it is an lcd fault you may find a replacement of ebay a cheaper solution ... Regards Vortash
ps and the beauty of that is you could sell your old unit minus the bulb as spares and repair and get some of your money back you just spent on the replacement .. lol
Posted on May 10, 2009
Construction master pro screen is dim / contrast is low
It uses batteries. So if contrast is dim, it may be time to replace the batteries.
Jan 30, 2014 | Calculated Industries 4065 Construction...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
hi,
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
ok
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
I would like to adjust the contrast for the 2400 dlp projector. The menu won't let me in to adjust the brightness, contrast or colours. what do I do to get into this area to adjust contrast?
Check the Manual From Support.dell.com and use the category Projector You may get some more info about the Menu options in details - Dell Tech
Dec 21, 2010 | Dell 2400MP DLP Projector
Going dim, POS NCR 7452 cash register 9" vga mono.
bcollier696, You did not state how many hours of use this small screen monitor has on it!! You may need to replace the CRT if it has been in use for a long time. Can you approximate the total "ON" time of said unit? Is it >10k hrs. Multiply hrs/day x 300 days x yrs of use. If u come up with 15k hrs or more replace the unit with an LCD if possible.
lmistyrel @ aol.com or louie12fix on fixya
Sep 16, 2009 | NCR Refurbished 9 MONOCHROME VGA MONITOR
Need help with a Benq PB6100 projector. The image is partial bright and clear, partially dim.
1st you have to connect your cables correctly, than set up your contrast in 50 if your contrast is in lower level, than adjust the sharpen and brightness with perfect adjustment remember do not place it near a woofer or speaker
For reminding me : trimoxibit@live.com dim
Jun 21, 2009 | BenQ PB6100 Multimedia Projector
Best settings for moderate to low light viewing?
Using your remote, click the "video" button (mid area, Right hand side) and adjust the brightness, contrast, etc., to your liking. Only you know what you like. If your picture can be "plenty bright enough"...then just make the necessary adjusts to whatever looks best to you. If your picture is "very dim" no matter what the video settings are, you need a complete cleaning of all lens, mirrors, and screen...and possibly a new lamp.
Apr 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Canon projector Dim & yellow
Yes, thsi can be a problem with the projector bulb and you may need to replace it already..
Hope that helps.........
Oct 03, 2008 | Canon LV-7230 Multimedia Projector
Picture is very dim
there is a problem in the flyback section of the tv set. the fly back has two knobs, one for screen and the other for focus. use the screen knob to adjust the brighness. if it did not help, either check the capacitors around the flyback or change the fly back with a new one. good luck
Jun 01, 2008 | Televison & Video
Optoma HD72 Multimedia Projector Logo
185 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
