Question about Microwave Ovens
I have a GE XL 1800 spacesaver. I'm attempting at swapping out the magnetron myself. One day it just stopped heating. Everything else worked fine, but normal sound of microwave was null and void. I called GE; they said they know of the problem, part will be free, but I'll have to pay for labor and service call..... I want to try to tackle this thing myself... Do you have any instructions/downloads that I may use to access this thing and swap it out? Thank you for your help!
  • Microwave Ovens Master
  • 9,098 Answers
Please refer to this file first for important safety info: http://www.microwavedisplay.com/safety.txt
You'll have to remove it from the wall, then remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here. (like JVM18##xx##)
Once you remove the outer cover, there will be a side panel which will have to be removed.
In general, there will be a lot of screws to remove during this job.
Posted on Sep 16, 2008
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacemaker XL 1800 microwave oven made in April, 2004. The Serial number is GG902192 B and the MN is HDM1853FJ02. It appears to work correctly, (it gets electricity and so forth,) but just...
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Light's on, plate rotates, no heat
When the microwave works properly but just doesn't heat, then the magnetron is bad and will need to be replaced. You can get the part and the diagram at partselect . com or repairclinic . com
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver microwave ...it is 5 years old and stopped heating
I have an over the oven microwave that blew a magnetron after 4 years. Could be the same thing. It was out of warranty for the free labor, so I took it apart (I'm kind of a geek) and found out the magnetron was gone. Shortening the story: I bought a new magnetron from an online place and replaced it and it works fine. If you have someone replace your magnetron, see if you can get it for free-they have a long warranty on the magnetron ($150 part) and at 5 years, you probably qualify. Rich
Mar 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
