Question about Dryers
Wont start, makes humming sound - Dryers
  • 750 Answers
Hi nigltdoobie,
Happ to hepl!
You said, The dryer wont start, makes humming sound
1. Check the outlet that it is still plugged in.
2. And check that the breaker is in the on position.
3. You may want to rule out the breaker being an intermittent problem by turning the breaker off and on once. ( As long as the breaker does not support something else on the same circuit that is vital)
IF SO YOU MAY WANT TO SKIP THIS STEP!
Be cause if the breaker is intermittently faulty, it may not restart after this and then where would you be if it the same circuit supports a freezer or fridge..
4. Unplug the dryer for 3 minutes and then after this time out try to restart it to see if it resets the system.
If after these tasks your dryer is still inoperable you will need hands on service to diagnose this situation!
Let me know what happens. Write me again!
Bless You,
huuum
Please give me a good rating before you sign off.
Thank You
Posted on Sep 14, 2008
Car wont start made a clicking noise first time, now no noise just a short humming sound. 95 Grand Marquis V8
check your battery terminal wire connector make sure they are secure and clean of any corrosion . and as for the humming sound I believe that is your fuel pump running when you turn your key to the on position
Feb 26, 2014 | Mercury Grand Marquis Cars & Trucks
2003 dodge caravan will not start. Makes a clicking noise, and dash shuts off, then makes a humming sound.
im going to say an almost dead battery .the hum you hear might be the fuel pump.you never heard it before because the van normaly starts .so boost your van if it starts you may have to replace the altenator the guages, no worries many cars do that .thats a code needing erased and if you disconnect the battery that may go away.
Nov 22, 2013 | Dodge Caravan Cars & Trucks
Fills with water and then stops makes a humming sound ,then stops all togther wont do aything spin or drain
sounds like an induction motor. start winding or start capacitor not starting to turn motor, This will make motor hum. Do not know m/c in qestion. Switch on and as soon as pos try to turn motor careful not to use hands or anything that can injure yourself with if it starts to spin.
Oct 29, 2012 | Whirlpool WTW5521S Top Load Washer
03 toyota corolla wont start makes humming noise
Sounds like your starter has failed, what your probably hearing is the solenoid trying to engage. Have the starter checked.
Jun 24, 2012 | Corolla 2003 Thru 2008 Books
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Dryer wont start
There may be a problem with the drive motor causing the humming noise
Dec 30, 2011 | Dryers
My 05 Corolla stop running.
Sounds like you need a fuel pump. The first indication of a fuel pump issue is a hum or drone noise.
Sep 22, 2008 | 2005 Toyota Corolla
Dryers Logo
207 people viewed this question
Top Dryers Experts
