No piture on the tv from dvd player but have sound. hve try 2 dvd players so I know that it is the tv
    Sergeant:
  • 300 Answers
Depending on how important the set is to you , you could get a schematic for it and start digging through the video circuits.
Posted on Sep 14, 2008
I have a Bahn TV ans a seperate dvd player. How do I play a DVDs through the tv
u cnt u hve to hve the dvd plyr the sme as the television!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! how many times do i hve to tll ppl!? how mny tmes? god u nd it the sme as the tele!!!!!!!! plz listen to this fcking hll
black%20background%201920x1200%20wallpaper_www_knowledgehi_com_99-40fjzo1pca3vsd2cwit0rkxs-1-0.jpg
Jun 05, 2017 | Televison & Video
I do not get a piture or sound
Check to make sure that your TV is tuned to proper channel (I.E., Aux 1, S-video, component 1, so on.) best to try with dvd in the player and just select the source input on your tv one at a time until you get the right one. If you are connected with HDMI cable, it should be one of those, if it is the standard yellow, white, red cable then it would probably be one of the "component" selections on tv input section....you may have to refer to your TV model and user guide to see which one is the correct one in correspondance to what you have hooked up....good luck.
Sep 14, 2010 | Coby DVD-937 5.1 Channel DVD...
Only audio works. No video. Worked fine last time. Tried new cables. Tried video 1 and 2 inputs to tv, still sounds great but no picture. T.V has no problem with video camera in either...
if the camera works, and you tried new cables.. it sounds like the problem is in your dvd player. make sure you have the video cable plugged into the correct slot on the dvd player.
Mar 01, 2010 | Oritron Televison & Video
I have a Memorex MVD2042 DVD Player and trying to hook the dvd player to my surround sound, the receiver on my surround sound has 6 rca hookups for each speaker for the dvd player. But as far as I know the...
There is only 2 audio channels on player (L&R) Is there any audio input jacks for just the red and white (L&R) connections. Or just for main speakers?
Nov 19, 2009 | Memorex MVD2042 DVD Player
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
My surroung sound wont play sound
Have you checked your connections?
Some surround soound systems have a source button (used to select the device you would like to play.
i hope this solution is helpful.
Feb 12, 2009 | LG Televison & Video
My tv shows are taping in black and white
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
electech
Nov 07, 2008 | Samsung DVD-V2000 DVD Player/VCR
Hook-up tv to stereo
You will require a sound system and TV that is compatible. I would not suggest to start modifying your sound system and TV. There are serious safety issues involved. There will also be the complexity of designing circuits to have proper impedance matching, input selection, and safe electrical isolation between the devices.
When buying new equipment, it is normal that at some time you will hve to keep up with the times.
Jerry G.
May 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Remote Sensor
Start a DVD playing, cover the IR sensor on the DVD player with something opaque. Try changing the volume, the player should keep playing. Your TV, surround sound, and DVD player have conflicting IR codes. The DVD player probably does not use a discreet IC to filter the IR sensor, and the processor in the DVD player is having to look at all the IR codes picked up by the IR sensor. Go to Walmart or KMart and buy a new DVD player for $29.00 or stop changing the volume while watching DVDs :) Sorry, there's no real solution that I know of. Paul.
Jan 01, 2007 | Norcent Technologies DP313 DVD Player
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
