NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS) Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my net gear n150 cd and i want to change my password..
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Sep 10, 2011
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511802
Points
4903
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
362
Points
I FOR GOT MY PASSWORD
2answers
I lost my belkin N600 DB Wireless N+Router Model:F9K1102v1 cd software,so i want to download it online by the net.
You don't need the CD to setup the router. I made a video showing how I did it to my F9K1003V1.
Unlock code password
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot up the laptop-computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program.
Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/
http://67.20.82.163/
Forget system password
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Need password breaking program for a samsung notebook NP-N150, on a USB flash drive
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD or copy to an USB memory stick. Then insert this CD or USB memory stick into the laptop/computer and boot up the laptop/computer with the Hiren's program and follow the instructions. There are very useful utilities and it a Linux boot program contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
2answers
Net gear wireless router N150 router WNR1000
Looking for the NETGEAR WNR1000 default password?
You probably have little reason to access your router on a regular basis so don't feel too bad
f you've forgotten the WNR1000 default password.
However, when you're troubleshooting a network problem and need to get in to the device,
the WNR1000 default password suddenly becomes very important.
For most versions of the NETGEAR WNR1000, the default password is password. As with most passwords,
the WNR1000 default password is case sensitive
Be sure to change the default router password on your WNR1000 to something more secure as soon as you're in.
Then use a free password manager so you'll never forget your new WNR1000 password
hope this helps
2helpful
Install without cd
Hai,
Go to your browser's adress bar and type routerlogin.net.
Now you will be asked to enter username and password.The username is 'admin' and password is 'password' itself.
Now enter all the settings in their places as said by your ISP.
I CANT install winxp on my n150,when i boot on my xp cd,it loads the drivers for installation then it restarts to the windows 7 starter again without prompting to boot on the disk..then i have to restart a...
don't worry.you can install windows xp edited version with your samsung n150.pls find windows xp blue lite edition , it has 32bit and also 64bit version.
https://computerworm.net/tag/windows-7-aero-blue-lite-edition-2016-x86-torrent-link/
2helpful
I have forgotten my password
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc.
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
10helpful
8answers
Need to reset password.
http://sourceforge.net/projects/pcloginnow/
DOWNLOAD PCLOGINNOW FROM THIS LINK
BURN THE ISO IN A CD
BOOT FROM CD
select an account and check 'is password empty' check box
IT WILL clear the PASSWORD for that account
10helpful
3answers
I forgot my password for windows 7, i also don't have reset disk, i'm using netbook samsung N150
You can use Windows Password Buster to create a password reset disk. With the disk you can easily reset the lost password.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
