Question about Zebra Printer 140-751-00000
Zebra 140Xill problem
When the labels or ribbon ends, after replacing them the printer doesn't recognize that the printhead is closed. I have to turn the printer off and on in order for it to recognize it. When I do that, the print job that it was in middle of printing restarts from the beginning. What can I do, so I don't have to watch and stop the printer before the labels or ribbon end?
Calibrate ribbon, Fallow The Procedure.
Remove Ribbon,
Press Calibrate,
install Ribbon,
Resume
Posted on Dec 02, 2008
    Scholar:
  • 45 Answers
Whenever you open the printhead, the Pause led will light.
If you hit the Pause button, the printer should go back on-line and resume printing (if you didn't turn it off).
If that doesn't work, try the calibration button (labels will feed out), then the Pause button, then the Feed button.
If you don't want to toss too many labels when you calibrate, the "maximum label length" (or some name like that) can be adjusted through the front panel.
Label_Guy
Posted on Oct 02, 2008
My zebra printer TLP 3844-z prints one label only, then stops and flashes red. It doesn't print subsequent labels.
There are 2 possible causes for this
1. Printhead not closed - check it is closed properly.
2. Either the ribbon or media is out. This cold also be a sensor problem. But it is worthwhile checking everything is loaded correctly.
Aug 19, 2011 | Zebra TLP 3844-Z Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
Z110xilll after 3or4 labels paper out error
Please run manual calibration
(take 2 or 3 labels and load the labels under the printhead and sensors, close printhead, press enter,
if ask for "take the ribbon," just open the print head, take the ribbon out from the sensors, close printhead, enter.
then if ask for load media, just put everything like you normaly setup the printer and press enter. The printer gona run the calibratio, Please close the door case, this can afect the sensors data.
save
tur off the printer and back on again.
run sensor profine. check if sensor check the gap (smal mountan )
Nov 12, 2010 | Zebra 110Xi III Plus Thermal Printer
I have an old Zebra 140Xill, will this do direct thermal transfer, do not have the manual
Press cancel for 5 seconds while power on to print config. Then check the following parameter.
direct thermal = no ribbon
thermal transfer = ribbon
Sep 16, 2010 | Zebra 140XiIII Plus Thermal Label Printer
I CANT LOAD THE RIBBON AND LABELS AND THE PRINTER DOESNT RESPOND
It does look a little strange inside, but here's the manual:
http://tinyurl.com/yb2rpd4
Loading the Media, p 12
Loading the Ribbon, p 17
Be sure the ribbon comes off the spool clockwise, and the labels come off the spool counterclockwise. Look carefully at the pictures in the manual and you should be able to load it ok.
Also be sure to close the printhead (the purple handle that holds down the ribbon and labels) to the 6:00 position when you're done. Then close the covers, turn it on and try it out.
Hope this helps you! If so, please leave a rating.
Mar 15, 2010 | Zebra Stripe S600 Thermal Label Printer
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
Printer Stripe S-500 Zebra
Question, when the printer prints is there an image of the data on the ribbon when it spools onto the ribbon takeup spool? If so, the ribbon may be installed backwards. I'm sure you know what you are doing but one must check even the smallest detail when trying to solve these strange problems. If the ribbon is installed correctly and there is no image of the data on the ribbon you may be dealing with a bad printhead and the printhead needs to be replaced.
Dec 19, 2007 | Zebra Stripe S500 Thermal Label Printer
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Zebra s600
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
Nov 21, 2007 | Zebra Stripe S600 Thermal Label Printer
Zebra Printer 140-751-00000 Logo
365 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
