Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitshishi vs-45605 again
Thank You for the reply! I gave you a fixya! Im looking for a part that looks like this....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=300257559350
This is the only mod that i have found and on that same page you sent me to they had the schematics for this same board. The problem is that i have a wavy screen and everyone keeps telling me to mod out the PIP module but i cant seem to locate it. I know that my tv hasn't had this mod already and i want to do it myself but i cant find the part.
  • 1,512 Answers
Thanks for the FixYa, I see now what your dilemma is. There is another ebay auction up that also claims there are 5 different PIP boards to mod out. check here
He may be the better bet to go with, and promises to email the mods to you and where to find the board. If they all look different,may be the problem you are facing. .The mod itself is just pulling the PIP PCB, and then jumpering the in/outs for video with a couple of capacitors. Its possible that some versions of the set don't have the PIP PCB, but unlikely . Do you have any pcbs that look remotely similar... the pcb may be different, but will have similer connectivity and function.
robotek
Posted on Sep 14, 2008
It comes on and then it goes off
This just happened to me as well. Keep it plugged in for about five minutes without trying to turn it on. Then try. This will ultimately tell you that your convergence chip is out. If the screen comes back on, it will look distorted. This is most definantly that chip going out. I suggest a tv repair kit or trash it. You can find a vs 45605 here: http://www.tvrepairkits.com/xcart/vs-45605/
Jan 17, 2013 | Mitsubishi VS-45605 50" Rear Projection...
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
Hi
Posted to the link you gave. Good Luck. Thanks for the request :)
regards
robotek
Oct 18, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605 with wavy lines
The first things to check are the filter caps in the main power supply area. Usually this rolling is caused by 60 cycle hum coming from the wall. Try that first and update this with your results. Also, while you are in there, resolder any joints that appear grainy or have rings.
Dan
Sep 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mistubishi vs-45605 pip module
The PIP board is small and square and stands straight up on the main board. It plugs into a socket. It also has a ground wire that has to be unsoldered to remove it from the machine. It is located essentially in the middle of the main board near the rear of the set. Sorry I can't describe it any better. Go to http:\\www.tritronicsinc.com or call 1-800-638-3328 for parts. Thank you!!
barneyluc
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
G'day mate
To all accounts it does, this can be checked by verifying that it has TWO antenna inputs. To get the PIP working, you will need to split and feed both antenna inputs. Seems to be set up this way to cater to PIP with set top boxes/convertors that have RF outputs
the 2 tuners can be spotted as the shielded assemblies with covers either side in the lower right corner of this pic. There is a mod floating around that involves bypassing the PIP to fix a fault that the set develops. This may have been done to your already.
check here for details.
Hope this helps you. A fixya rating is a great thankyou for my efforts to assist you . Cheers
regards
robotek
Mitsubishi VS-50705 convergence problem.
There should only be a couple of STKs, the R's are resistors, they STKs should cost under $20. This should be everything you are looking for. If you need anything else, let me know.
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
Ref # / Part # / Part Name & Description
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
Jun 05, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs 45605 no picture
yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
May 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 convergance
you will need to replace both convergence i.c.s as a pair
Nov 27, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
