Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
How c can i use my phone as a modem to connect to the internet
I can not download internet file in motorola z3, i try but always failed
Posted on Sep 30, 2008
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
How to connect champ 3303 to pc using internet as a modem
go to your control panel in pc....
then open phone and modem options go to modem properties and then call to cust care they gave you a extra entilization command
Jan 21, 2011 | Samsung Modem Configuration Software...
Can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
Apr 07, 2010 | Dell Computers & Internet
Can I use the Samsung alias 2 is an Internet modem
    Using Alias 2 as Modem
  1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
    In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
    At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
    It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
The modem works great until the phone rings. I am
check the splitter and make sure your phone is connected to "phone" and internet is connected to "DSL or DATA. our neighbor has the same problem and when i checked the splitter, the phone is connected to "data" port.
Nov 04, 2009 | 2wire (1000-000057-000) Modem
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Nokia 6070 internet connection
www.blogfortech.co.cc
go to this link u will find the PC suite for Serial cable
Download that and install on your PC/laptop
Connect ypor mobile to PC/laptop via CA-42 cable
When youR phone gets connected to your PC/laptop
go to control panel and then in phone and modems and
go to modems and select add new and click on 'dont insatall my modem i will select from the list'
after that select manufacture nokia and select modem of NOKIA 3200 and select the port ON WHICH YOUR PHONE IS CONNECTED
dont select the different port you will not be connected to internet.
and finish it
NOTE:-Install your modem only when your phone is connected.
Go to PC suite and click on the modem you installed
and provide your Operator setting and you have done it.
NOTE:-when your connection is Established your Phone will be disconnected from the PC suite
After disconnecting from the internet Your phone will again connected to PC suite.
ENJOY...........
Jan 08, 2009 | Cell Phones
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
USB external modem
The phone connection would need to go through the blue tooth regardless of if you're using the phone connection or not. Check to see that you have bluetooth turned on and setup first. Then you'll need to use that to create the settings for using the phone as a modem. However, if you are using Windows on your Mac, you will need to make sure that your computer has the drivers installed to be able to both connect to the Internet and to connect to your phone. Once that is set up, you still need to go through the steps to use bluetooth to connect your phone to your computer, establishing a connection. There are quite a few articles about creating connections through your phone as a modem. http://mobileoffice.about.com/od/typesofaccessavailable/ht/bluetoothphone.htm
http://www.theinternetpatrol.com/how-to-connect-your-computer-to-the-internet-using-your-cell-phone-as-a-wireless-internet-connection-or-tethered-modem
Mar 01, 2008 | Apple MacBook Pro Laptop Computer with...
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Vernon Taylor
Timllfixit
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
