Question about Maytag Neptune MCE8000AY Electric Dryer
Maytag neptune drying center
Hi Bean. Love that guy!!!!
I have a NO HEAT problem. Measured the element and the other two switches on the boad with the element. The two switches read 0 ohm and the element read 13 ohms. Still no heat. Did the reset to the logic board. Still no heat. Vents are really clean now. Still no heat. Any other things to look at or is it time to call THE MAN?
Thanks
  • airbear72 Sep 15, 2008
    All those who are on the NET looking at this, you should trust this guy. He REALLY knows his stuff. Spot on with everthing and the detail guided me to the problem.
  • marleneinvt Jan 06, 2009
    I have a Maytag Maytag MCE8000AYW I have replaced thermostat and now heater coil went, with NO replacement part available. It is just the coil and Maytag is no help sent me to a obsolete parts place in California who couldn't locate one either. By the way I bought it four years ago for 1200.00.
    marlene_05301@yahoo.com
  • 5,911 Answers
I apologize for not getting back to you sooner. Look for a thermal cut-out, thermal fuse, along with the Hi-Limit Thermostat inside the dryer. Some manufacturers call them thermisters. These components act as fuses and are designed to protect the dryer heating circuits from overheating. If these components fail, they will open like a fuse. They are not resettable (one shot) and must be replaced. The manufacturer places a wiring diagram inside the operator console. These components should be listed on that diagram, and are generally mounted in close proximity to the heating element. The manufacturer also recommends that you replace the hi-limit thermstat and the thermal cut-out (fuse) together if either is found to be bad. They are commonly sold as a set. If you go to searspartsdirect.com and type in your complete model number the components I mention are listed under the "Cylinder, Heater and Bulkhgead" heading as items 17 and 21. I hope this helps you. Let me know if I can be of further assistance.
Posted on Sep 14, 2008
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
My maytag neptune eletric dryer is not drying my cloths only cold air circulates. checked continuity of heat element,good, no limits or fuses open, 120volts to each side of the element. What am i missing?
Should have 240 volts at element.  If it has continuity, you will read the same voltage on either side.  Check across the element for 240.  If you only have 120 check for 240 across the two outside terminals where the cord hooks up.  More than likely either a half tripped breaker or defective breaker.
Dec 19, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer is not drying/ what do I do first
to check the element you need a continuity test this test insures there aren't any breaks in the heating element that you can't see. If there is continuity then you possible could have a hi limit switch (this looks like a small round button about the size of a dime, located in the housing holding your element) burnt out. If the element is burnt out there will be no continuity on the element. If there is continuity then take the hi lmit swithch out and replace it. Take the model and serial numbers to an appliance parts store for replacement. Good Luck
Dave
Jul 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Wont dry
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 03, 2009 | Maytag Neptune MDE4000 Electric Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Drying Center MCE8000AYW
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
1,196 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
