Question about Whirlpool 24 in. DP840D Free-standing Dishwasher
Dishwasher isn't draining
My portable dishwasher doesn't drain..the water is very slow to almost none coming out of the hose..The water flows into it fine and it washes great...is it the pump?
  • Anonymous Feb 17, 2009
    mine drains but still leaves water standing. does the cover come off where it drains?
  • 641 Answers
It could be the pump, but not only. Check first that you don't have any clog in the drain line. If drain line is clean, open machine's rear panel and : - Look if the pump works. If it doesn't work check that pump get power (with multi-meter). In case it get power (and does't work), it should be replaced. - In case the pump works - The machine has a drain valve with an electric solenoid (the drain pipe connected to it). When it get power the valve opens and diverts the water to the drain line. Test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !
Posted on May 29, 2006
SOURCE:
I have a small dishwasher it goes through all cycles water won't drain out of the bottom
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Tip
How to repair or fix a Dishwasher if it doesn't drain
Dishwasher Doesn’t Drain Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn’t pumping water out properly, the drain hose isn’t carrying it to the drain pipe, or the house’s drain lines are backed up.
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you’ve recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn’t drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
on Sep 03, 2010 | Dishwashers
Water does not empty from dishwasher
Hi
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
The dishwasher does not completely drain.
Hi
Thanks
Rylee
Jun 10, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Water won't drain
Hi
Thanks
Rylee
Jun 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher doesn't drain when i run the dishwasher it doesn't drain the water out.
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Dishwashers
Water does not drain 'Fast 40' and 'Delicate' lights come on to indicate a fault.
Hi
Thanks
Rylee
Nov 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher is not draining
Hi
Thanks
Rylee
Nov 09, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher keeps washing, doesn,t go through the cycles, i have to push cancel and drain.
Hi
Thanks
Rylee
Oct 27, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Whirlpool 24 in. DP840D Free-standing Dishwasher Logo
289 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
