RobertShaw Thermostat 9600 problem
It blows hot air when it's supposed to be cooling off.
  • MiaSR Sep 14, 2008
    Yes, it is, but not below 75, it's set at 78. The other thermostat (we have 2), for the upper two floors, is also set at 78, and has been working fine. The house is a new construction.
    Thank you.
  • francis rivero May 11, 2010
    is the thermostat set to cool mode?
    is the setting below 75 F?
    tnx 4 using fixya,
    drcool
  • 958 Answers
Verify if you have separate units for each floor.
the ones working could be a complete separate unit from the one having problem.
look at the condensing units you got outside , how many are there?
if you have 3 units outside and you have 3 thermostats, then each thermostat is controlling individual split units.
we have to concentrate on the one that is not cooling. give me the details on what is going on with problematic one.
is the outside unit running?
is the outside fan running?
can you distinguished if the compressor is running the same time as the fan?
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
Why does the heater blow hot air when I drive after its been idling for 15min and not during the idle when it reaches the 100 Temp?...(it blows cold air in idle)
Firstly, a thermostat that opens quicker will not give you better heat. Your heater core may be partially plugged causing a low flow issue. Another area to check would be the water pump impeller for corrosion or slipping on the shaft. Does the vehicle's cooling system operate well otherwise?
Jan 27, 2015 | 2002 Pontiac Grand Am
It is required to connect the RC and at least one of Y, G or W leads to set the date?
If there is no place for batteries, then yes, connect the Red wire for 24Volt power on the R ...& Common to the C.
Jan 16, 2015 | Robertshaw 9600 Heat / Cool Digital...
My Robertshaw 9600 displays 99 degrees and because it is satisfied, is not calling for heat. The temp is actually in the lo 60's and falling. I've tried battery replacement, but nothing changed. Other...
Hmm. I don't think it posted the first time around. So I'll try again.
There is a temperature sensing diode on the back side of this thermostat's circuit board. This diode may have failed or become disconnected.
I'd lean towards its having become disconnected, as I've been inside an example of this Robertshaw (originally Maple/Chase) 9600 thermostat and noticed that the soldering on this part was of poor quality. So if you have a soldering iron, and know how to use it, you could probably fix it.
I have a web page (just the facts, no ads, malware or fluff) that talks of some other common problems with this thermostat and how to fix them:
http://greyghost.mooo.com/maplechase9600/
Feb 04, 2010 | Shaw Robert RS-9420 Thermostat
How to install maple chase 9600 thermostat
The manual is very specific.  http://www.icca.invensys.com/manuals/robertshaw/110-653B.pdf    The Robertshaw 9600 is the same unit. The terminals marked RH, RC, W, Y, G are where you put the wires, just loosen the set screws with a small flat head screwdriver, insert the bare wire into the hole and tighten the screw. Leave the jumper between RH and RC for most installations. The red wire goes to the RH. Please come back and comment if you need more specific help. Good luck
Jan 08, 2010 | Heating & Cooling
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
2 zone sytem main floor cooler than what i set it to
Warm air rises and if the upstairs thermostat is on it will onerride to lower the temp upstairs. To have the dowstairs thermostat govern, the up stairs must be off . The whole house will balance to the controlling thermostat.
Jun 02, 2009 | Honeywell Programmable Thermostat Heater
Thermostat problems
Have you confirmed that the thermostat is programmed correctly?
Did the thermostat ever control the temperature of the house properly?
When you indicate "kick", are you talking about flipping the Auto-On switch back and forth? The Auto-On switch only controls the fan, and no heating or cooling (Auto - fan runs on call for heat or cool, On- fan runs all the time.).
If "kick" means making the heating work, and if you have the same problem for making the cooling work, chances are good you have bad thermostat.
If the problem only occurs with the heating, and cooling works fine, then the problem could be in the controller board of the furnace, assuming you have a more recent (1990's or newer) furnace.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
646 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
