Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
Washer seems to leak during wash cycle does not leak at final finse and spin. both pumps not leaking. also right side(side with disharge pump) and back become wet inside approx 2/3 up unit also only looses approx 1/2-3/4 gal water on floor. just removed 2 coins out of recirculator pump but noise from pump and leak happened same time any ideas
  • Anonymous Apr 04, 2009
    Lots of clicking and clacking sounds when draining and then leaking on the floor
    President:
  • 1,462 Answers
Coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Posted on Sep 14, 2008
Water leaking durIng cycle of machine what is a fix and a part number whirlpool cabrio
You need to give more details. It could be leaking from the water supply to the washer. A recirculating pump clamp could be loose, or a coin could have caused a small hole in the pump side wall. Or you might have a worn tub seal.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking water from bottom of washer
Did you hear a clicking noise during the spin and drain cycle? If so, then change has gotten into the tub and discharge pump and cracked the plastic housing on the pump. had the same problem. Had to replace the pump.
Nov 25, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Water is leaking from the washer when performing
you have a leak comming from either the pump seal of pump outlet hose
May 15, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Washer leaks during spin cycle
hi sir, if water leaks during the spin cycle please check the following:
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
mostly water leaks due to the above problems. kindly check them.
kindly rate me.. thank you for using Fixya.
Feb 11, 2010 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Washing Machines Logo
482 people viewed this question
Top Washing Machines Experts
