Question about Sharp XL-DK225 Shelf System
Sharp XL-DK225 won't turn on; timer light blinks
My Sharp XL-DK225 won't turn on. When I push Power/Stand-by button the unit briefly flashes "Power On" then unit makes click sound and turns off. The timer indicator light flashes, but to my knowledge was not set. I've done the reset (P+CD1+CD5) and unit briefly flashes "Clear All," makes clicking sound, and turns off. Have unplugged unit for 24 hours, but same thing happens when I try to turn on.
I've got CDs in unit. Is there any way to manually open CD trays before I send unit for service (or trash it).
SOURCE: sharp XL-MP130 CD shelf sys. won't work...at all
Hi There,
The clicking noise is usually the power supply "tripping" because of an over load, your explanation of the fault is very good and helps us in advising you about the fault...
Because the clicking gets slower it means that you have reduced the current being drawn from the power supply.
The item that is causing the over load is the item that when you plug it in or turn it on causes the clicking to start up...
Tyhe power supply is called a switched mode power supply and is usually a collection of transistiors capacitors resistors and a transformer all specially set up to make DC Direct Current and AC alternating current power for your electronics to work with.
These power supplies are expensive and no fuses are employed to make them work but a special detector circuit is installed to close down the power when a high current draw down is detected, Once the high draw down is detected the power supply closes itself down, so then it sees no more high current draw down so it starts up again and this causes the click as the internal transformer and capacitors once again start the cycle to operate to make the DC/AC supplies. So once started up the High current is detected and the power supply closes it self down and the cycle is repeated over and over....
Its a specialised job to locate the problem so its not something you can do your self without electronics training...
Cheers From YUBEUT
Posted on Nov 24, 2007
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
Posted on May 23, 2008
SOURCE: remote
RRMCGA133AWSA
Posted on Sep 02, 2008
dehowletts
  • 14 Answers
SOURCE: Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Posted on Dec 17, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
How do you turn on XL-DK225 without a remote.
Your bargain XL-DK225 may have experienced a terminal failure that can't be repaired.
Feb 24, 2017 | The Audio Players & Recorders
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
Aug 19, 2008 | Sony Televison & Video
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
Power won't shut off. Hello message and scramled lights comes on as soon as power off is pressed on Sharp XL-DK225
The stereo is in Demo mode. Press the "x-bass/Demo" button on the bottom of remote to turn off Demo.
Apr 24, 2010 | Sharp XL-DK225 Shelf System
Unit will not come on, but timer button is blinking
Well, it thinks it's set to come on under Timer control.
Get the manual out (or go to retrevo.com, register and download it for free) and go to page 34 and cancel the timer.
Canceling the timer setting in the timer stand-by mode:
1 Press the CLOCK/TIMER button.
2 Within 10 seconds, press the or button to select
"ONCE" or "DAILY", and press the MEMORY/SET button.
3 Within 10 seconds, press the or button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY/SET button.
Timer will be canceled (the setting will not be canceled).
Mar 10, 2010 | Sharp XL-MP130 CD Shelf System
Lights flash on the unit at night making it hard to sleep!
The power button does nothing in relation to this!!! Press the x-bass/demo button at the bottom of the remote. That should fix the blinking lights! :)
Feb 26, 2009 | Sharp XL-DK225 Shelf System
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Dan
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Sharp XL-DK225 Shelf System Logo
575 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
