Question about Kitchen Ranges
One burner unit does not heat at all - Kitchen Ranges
Have GE technician coming out tomnorrow.
Thanks
Posted on Sep 15, 2008
Need to replace heat sensor, where is it located on the unit?
there should be 3 heat sensors on the unit. Incoming water to decide if it needs heat, outgoing water, and a sensor on the burner(flame). the in and out sensor should be behind a panel near the inlet and outlet pipes. The burner sensor is more tricky usually near the igniter or below the heat exchanger inside the unit.
Jun 18, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
When I turn it on to the heat cycle the fan does not run, I have swapped the control board with another unit that was working and still get the same result the unit runs on all other cycles.
This is not true if your system is a heat pump. When the thermostat calls for heat, and the burner ignites the gas, a thermal sensor switch senses when the hot box has heated and then the sensor turns the fan on, this is so no cold air is blown into the ducts and living space. Also, another sensor senses the heat box if it gets too hot, cuts out the burner, if this sensor is not working then the burner will never light. Two sensors that may be keeping the heat from working among other possible causes, one step at a time in trouble shooting. Does the burner turn on at all?
Apr 25, 2015 | Heating & Cooling
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
Bottom burner won't heat up
shut the breaker off to the unit. if the bottom burner is exposed remove the screws at the back of the burner and ease the burner out. there will be a wire connected to each side of the burner. remove both of the wires and test the connections of the buner for resistance with an ohm meter if open you need a new burner if not it could be a control. this is assuming your range is electric not gas
Mar 27, 2012 | Ovens
How to i clean burners i cant get unit to heat
Hello. Remove the burners, wrap them in ammonia soaked layers of newspaper and slide the whole thing into a large plastic bag which you close with a twist tie. Next day rinse em off, remove any loose debris, let em air dry and..... enjoy your clean grill burners. Joe
Mar 20, 2010 | Weber Genesis Silver B Grill
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Is it all right to use cast-aluminum griddle which covers two burners on a smooth top electric stove/
I would avoid it unless the manufacturer says its okay.  I'd get in touch with them.
You did not say what kind of heating system the unit has.  Induction units will not work right with multi-burner systems and other systems such as radiant burners will cause heating that is not in the right places.
Dec 12, 2008 | Kitchen Ranges
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
