Question about Alpine MRD-M1005 Car Audio Amplifier
Alpine MRD-M1005 Subwoofer Amp Problem
When my Alpine amp is hooked up to my subs, right away when it is turned on, it sends this this really loud bass vibrato type of sound to my subs. When my deck is playing music or not the only thing I hear is the loud vibrato bass noise. Someone told me that it might be something wrong with my ground terminal. If anyone knows what the problem is and how I can fix it, please help.
Here is my problem: For the past 2 months my subs have been cutting out at relatively low volumes. If I turn them up loud enough (about 1/2 max volume), they pound like crazy! It's just at lower volumes or songs with little bass that the subs seem to cut out or simply produce no sound at all. The blue screen is still on like everything's still working but subs aren't pounding. This is a new problem as I've had the system for nearly 1 year and a half with no issues.
My setup: The sub amp is an Alpine MRD-M1005 1000w monoblock. It is powering two Alpine 10" type R subs (2ohm) in a porded box
Posted on Feb 22, 2018
    New Friend:
Try a small piece of wire install it to the rca plugs in back of the head unit strip the end that's plugged in
Posted on Jan 31, 2015
  • 35 Answers
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Posted on Sep 16, 2008
Have 2 4+4ohm avi sl500 subs how do i wire it to this amp and what setings on this amp alpine mdr m1005 1000watt amp
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
Jan 19, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
I have a kemwood kfc-3012 12" sub what size amp do i need to run it
it depends on how loud you want it. If you are looking for it just too wok good, 400 watts would be good. don't exceed 1200 watts peak.
Nov 22, 2009 | Alpine MRD-M1005 Car Audio Amplifier
When I hook my JL W7 sub to my alpine mrd m1005 amp the sub is pushed out and stays that way
Hello christensen7,
It sounds like there's DC current on the amp output terminals. Disconnect the sub and test the output with a multimeter. If there's DC there, most likely the amp is shorted internally and needs repair.
Hope this helps.
Aug 17, 2009 | Alpine MRD-M1005 Car Audio Amplifier
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Audio & Video
I would say any decent pair of 12" or 15" (single 4 ohm voice coil) subs that can handle at least 500W rms would work. The rest is going to be based on cost, type of box, type of music, etc.
Feb 20, 2008 | Alpine MRD-M1005 500W x 1 mono subwoofer...
Alpine mrd-m500
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Alpine MRD-M1005 Car Audio Amplifier Logo
210 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
