Question about GE JVM1861SF Microwave Oven
Microwave malfunction the model is a GE spacemaker xl 1800. It shows F3 in the display and does not do anything .It beeps but nothing work
  • Anonymous Nov 26, 2007
    last year our microwave Quit working and showed F3 after 2 weeks I plugged it back in and it worked. Now it is doing the same thing.By the way when it quit working the first time some of the buttons did not work. example 2min 30 sec.
  • GE Master
  • 9,098 Answers
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
  • 641 Answers
F3 means - Shorted key panel (touch pad) and it occur when a shorted key panel is detected continuously over 60 seconds. In this case the key panel should be replaced. Good luck !
Posted on May 29, 2006
I was also getting F3 error code on GE spacemaker xl 1800. After reading prior post about possible faulty keypad, I unplugging and touching each of the keys on the control panel. After touching most of the individual keys, the problem solved itself. Back to having a working micro. Thanks for the help!
Posted on Jul 10, 2007
What about Demo Mode? How do you get out of that?
Posted on Mar 01, 2007
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
F3 and beeping on my GE spacemaker 1800 microwave oven...what causes this?
F3 is the code for a failed membrane keypad.
On most of these GE models, the keypad is not available as a separate part.
So you'd have to order so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 27, 2011 | GE Microwave Ovens
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error ge Spacemaker xl 1800: Model JVM1851CD. What does F3 mean?
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microware Hood SpaceMaker Problem
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Jul 05, 2008 | GE JVM1850 1000 Watts Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1861SF Microwave Oven Logo
1,517 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
