Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 5yr old washing machine
Have a leak from under the machine. looks like it's coming down thru the motor.
  • michael parker May 11, 2010
    hi my top loader is leaking from looks like a breather hole above drive motor .how do you replace main seal does the shaft have to be knocked out?
  • 70 Answers
Sounds like you need a new main seal.
Posted on Sep 21, 2008
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
My washing machine will not light up
Generally this problem happens when the drain pump starts to leak under the washing maching. A Fisher Paykel has a main control board under the touch panel that has direct wires running from it to the drain pump. When the drain pump leaks it shorts out the wire connecting it to the control board and blow out the main control. Look under washer and look for the drain pump (Drain pump looks like a fan from the underside.) You will most likely see residue from where the water has been leaking, built up on the pump. If all of the above is true on your machine, replace the pump and control board. Fisher Paykel includes an inline fuse to keep this from happening again.
Mar 30, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
I have a 5yr old Fisher and Paykel GWL11 Top Load Washer that is running very slow on sin cycle and has a screeching sound when trying to spin. Due to the squel, i 1st thought is was a worn belt, but...
sounds like your bearings have had it. if it washes it is not the motor. the sound u hear is the rusty bearings. to repair this u need to change both bearings, main seal and possible shaft. if u want to give the repair a go i will try to guide u thru it. but i must tell u it is a big job if u havent done it before. please reply 4 more help if needed
Apr 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Ecosmart (about 6-7 years old. Spin
better get e a new one, it is most likely the bearing , can u see small amounts of water under the machine, if u want to take the top off all there r is 2 screws under 2 D shaped covers under the lid towards the front of the machine ,,,,wont help , but it also cud be a wire in the drain pump
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
Fisher and paykel gwl15 leaking water from under machine. Unknown where leak is coming from. Want to look under machine ourselves before calling in experts.
If it is leaking during fill cycle then it is probably the fill tube. If it is leaking when it drains it is probably the drain hose on the bottom of the drum. If you do not know when or where it is leaking from get a piece of card board and put it under the machine and run the cycles checking the cardboard between each cycle to find out when and where it is leaking from.
Jan 16, 2010 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & paykel smart drive washing machine leaking water
If your washer is still under warranty, I would call the company and have them send someone down. If the leak is from either the drum itself or a seal then I don't think you could handle it yourself. But, first make absolutely sure that it's not from any hose connection. Tighten all the connections, especially those to the drain pump. And check the pump itself for any leaks.
Mar 02, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
175 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
