XFX GeForce 6800 GT,  Graphic Card
Problem for XFX GeForce 6800 GT, (256 MB) Graphic Card
Geforce 6800 GT 256mb PCI-E DEAD
By lucky9ball on May 29, 2006
When it boots nothing happens, seems to be dead. any help thanks
Comments:
May 29, 2006
- im running windows XP home, and yes it didnt work first time i put it in.
Same Problem
May 24, 2008
-   I have the same problem with a Jetway Nvidea AGP card N6800AD256. I BOUGHT IT NEW FROM 3bTECH.NET
If so, it might be a counterfiet Jetway card, as Jetway says my boards part and serial number doesnt match their number system.
The computer wont boot up, it just beeps continously. IF OTHER CARDS WORK OK IN THE SLOT, the board is bad.
-   JAQUEBAUER
May 02, 2008
-   I WONT A DRIVER FOR THIS eVGA e-GeForce 6200 256MB DDR AGP Graphics Card-256-P2-N341-LX
AGP CARD-   ranjitjadhav
Apr 20, 2008
-   have a asus en8600gt, first after installing card into motherboard it would go to the windows loading screen and then blank. Followed asus guide of checking bios clock and reset bios to default setting's and now it just goes straight to a blank screen with a flashing _.-   huggybear1
Best Solution
posted on Mar 22, 2007
Very Helpful)
Kaldorei
Rank: Apprentice
Rating: 100%, 1 votes
I'm having the same problem with my AGP version of that video card, and am also running Windows XP.
How can I use the Add Hardware wizard when I can't even boot up the machine with my new video card? I uninstalled the previous one, but the computer still just hangs at bootup.
Was this helpful?
Yes
No
Solution #2
posted on May 29, 2006
Helpful)
Nightdiver
Rank: Guru
Rating: 87%, 169 votes
Hi lucky9ball,
This is a great card, that requires you to plug in a power plug from your power supply to the card directly. If you have already done this, short your CMOS pins to reset your bios. Let me know how it works.
Best regards,
nightdiver
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
dovi
Rank: Guru
Rating: 88%, 2505 votes
Does it the first time to be installed in your PC ?
Which OS do you run in your PC.
Comments:
May 29, 2006
- Go to the "Control panel" , choose the "AddHardware" icon
and follow the instruction relates for a new hardware.
If it will not help - replace card's location (other PCI connector) on the motherboard (be aware you should disconnect first power cable to PC) restart the PC and see does the PC find a "new hardware".
Let me know if you will need for any more assistance.
Good luck !
Was this helpful?
Yes
No
Solution #4
posted on Aug 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ati 9600xt
failed driver
Solution #5
posted on Dec 22, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I am having the same problem. The DVI port sounds dead and gone. Get a new card.
Solution #6
posted on Nov 25, 2007
Not Rated)
stevenkabc
Rank: Apprentice
Rating: 0%, 0 votes
My Primary DVI port died when running a new LCD w/Dsub converter. Only Seconday port is working. The primary is receiving a signal (see size change in blackness during boot). How can I get Primary DVI back or is my 6800 PCI-e now half-dead for good?
Was this helpful?
Yes
No
Solution #7
posted on Nov 23, 2007
Not Rated)
Jammy Dodger
Rank: Guide
Rating: 96%, 7 votes
If their is still a problem your graphics card has not been set as the default display device. keep the graphics card plugged in, restart the computer and as soon as it starts up go into (BIOS) which is the delete key on most computers. The bios screen will appear as a light/dark blue. Scroll through the menu's and find where it say: AGP port selected or something femilliar and change it until it comes up with PCI-E (meaning PCI express) and click done and save and exit, the computer will then automatically restart and the graphics card should start up and display colours on screen.
I hope this helps resolve the problem, if you are having any other problems feel free to contact me on hear or by email to: neo89@hotmail.co.uk
Was this helpful?
Yes
No
Popular Solutions for XFX GeForce 6800 GT, Graphic
Questions and Unsolved Problems for XFX GeForce 6800 GT, Graphic
Do you recommend XFX GeForce 6800 GT, (256 MB) Graphic Card?
Answer
Answer
can you update the graphics card in a gateway gt5482E? I attempted to install an Nvidea 9800GT, and... (More)
Answer
Hi, I have a Ibm netvista tower, p4 1.7ghz 512mb of ram. Im having a problem with Grapchics. I know... (More)
Answer
my asus p7131 capture card is recognised in win 7 (64) but all i get is sound (Echo's a lot) and a... (More)
Answer
Need to replace the fan on an HIS x1650 pcie board - 256KB. Need a repair source or source for the... (More)
Answer
dell e219542 vga driver
Describe your Graphics Cards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Graphics Card Experts
Top Computer & Laptop Repairmen
in , TX
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
