First, it is not a netbook. It is a notebook. The Aspire netbook is a Chromebook. The Aspire notebook you refer to has an XP operating system.
https://neosmart.net/wiki/acer-recovery-disk
Download Drivers and Manuals Acer Official Site
But you may only see the 1640 and 1640z listed.
FYI:
Acer Aspire 1642WLMi Specs
IOBit.com has driver booster that will scan, identify, download, and install drivers. There's a free version and a paid version. This is assuming you're using Windows 7 or higher.
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
SOURCE: Installed XP Pro on Acer Aspire 5050
You need to install some drivers. Did this machine originally come with Vista?
check for an update of bios on acer.com it will fix your laptop problem....
SOURCE: modem device on high definition audio bus
Go here for downloads for your laptop.
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
I hope this helps.
SOURCE: installing anti virus onto aspire one net book
Hi, the Acer Aspire is a Linux operating system based computer. It does not run Microsoft windows in the same way that Apple computers run OSX, not windows. The antivirus programs you mention are for windows computers. On the bright side, running Linux you really DON'T need virus protection Linux is inherently far more secure than windows.
Microsoft Help and Support says that "Code 28 (The
drivers for this device are not installed)" appears when the Windows Sound
System Compatible Driver for the Windows 2000 operating system is deleted upon
the upgrade to Windows XP. It's possible to repair this code.
Instructions
1 Click on "Start."
2 On the "Start" menu, click on "Control
Panel."
3 In the "Control Panel" folder, click on
"Performance and Maintenance."
4 Click on the "System" folder in the
"Performance and Maintenance" folder.
5 Click on the tab titled "Hardware."
6 Click on the box that says "Device Manager."
7 Click on "Sound, Video, and Game Controllers."
8 Right-click on the device that prompts Windows XP to
display Code 28 (it should be Windows Sound System Compatible Driver, also
called the WDM driver). A drop-down menu will appear.
9 Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
