Panasonic NV-DS65 Mini DV Digital Camcorder Logo
Posted on Sep 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to down load tape to pc
Pls guide how to down load from video tape to pc using panasonic video camera?
  • Anonymous Oct 02, 2008
    i have NVDS 65 . i dont have the sothwere to transfer the tape to my leptop
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Oct 05, 2008
Anonymous
Expert
Level 2:
Answers
104
Questions
Helped
25601
Points
285
I have uploaded the driver here:
http://rapidshare.com/files/151262301/Driver.rar.html
un rar and install it on the computer.
when you are done installing the driver proceed with the movie transfer as follows:
1- conect the camera to computer
2- open moviemaker program
3- choose option - capture from video device
4- You will have a choice of devices depending what else ic connected - choose panasonic dv
how to down load tape to pc - 1e8e85b.jpg 5 -at the selection screen choose - best quality for playback on my computer
b369d7e.jpg 6 - start rhow to down load tape to pc - 1543b9c.jpg /> 1543b9c.jpg
Power turns off after about 10 secs of watching the video
First guess is the camera has dirty heads. Suggestion is to run a head cleaner in your video camera. Regardless of the instructions on the head cleaner, I usually run the head-cleaner tape on "Play" for about 10 to 15 seconds, and then on "Record" another 10 to 15 seconds. Wait for 10 minutes before loading your playback tape. Try playing your tape again.
Also, check to be sure the tape is loaded properly and that the hatch closes securely and properly. A hastily loaded tape or an ill-fitting closure could cause the play function to stop.
If this does not solve the issue, it may be something in the play switch or in the playback mechanism that requires repair services. If the problem continues, I would recommend calling the Panasonic Company and speak with Tech support or Video Camera Repair. They may be able to tell you and estimate of what it would cost for the repair.
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
3helpful
2answers
How do i download my tape to my computer so i can put the images on dvd. my camcorder is an old panasonic nv-rx10eg with a small cassette
Install a capture card (Firewire card) in PCI slot.
Install a video editing software in PC.
Capture video in PC and edit as per requirement.
Go to 'share' or 'make movie' option to render the edited video.
Make DVD with that rendered file.
Thank you,
Gautam Kumar Mandal, M.Tech.
Addl. Chief Industrial Engineer,
Durgapur Steel Plant,
Steel Authority of India Ltd. (SAIL).
4helpful
How to copy video from a panasonic NV-GS57 to a computer
I am not able to copy video from my panasonic digital NV- GS57GC to my PC.Pls help
3helpful
3answers
Panasonic Palmcorder 700x Digital zoom VHS-C
can i down load my tapes to my pc with the panasonic palmcorder 700x
Eject tape
This problem of yours could be caused by dampness or moisture in the camera. Try to keep the camera in a dry area or dry the camera where the mini tape is with a hairdryer at a sloe warm speed.
Sam
+27824692985
2answers
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
