Question about Philips Magnavox 51MP392H Rear Projection Television
No Picture no sound.
We were watching a movie when suddenly the picture and sound went away. When the tv is on you can hear a steady clicking noise. Is this something that will cost a lot to fix? We have a 52" magnavox rear porjection tv. Please help as much as you can.
  • Anonymous Nov 11, 2007
    I have the same prblem.
  • Anonymous Jan 02, 2008
    takenpower bqard ot checked ok tookthemother board out and checked it seems like every thing is ok.main cap.holds charge so yoy cant go any farther tochk it,.
  • Philips Master
  • 3,459 Answers
Check www.magnavoxhelp.com. They have instructions and kits to repair this problem.
Posted on Jun 24, 2008
Sound quality very low
Posted on Feb 04, 2008
    Problem Solver:
No on o no prende nomas flachea el boton del power
Posted on Jan 02, 2008
If you are a qualified technician then you can try removing the flyback transformer FBT and have it check thru a flyback checker from any electronic repair shop. You will be able to confirm whether you have a problem in the high voltage section. Which would likely is the case. If FBT is OK look for a shortgae in the horizontal section specially the horizontal output transistor. good luck
Posted on May 29, 2006
    President:
  • 3,130 Answers
This fault sounds like a high voltage shutdown or the high voltage fault. It is not a repair thst a regular handyman should attempt to repair unless they have electronic background. I you want to attemtp yjr repair yourself and you understand the technical lingo then you can get a schematic diagram and start to troublrshoot the horizontal out section and move your way through to the main power supply but I bet you find a short in the first place I said Good Luck
Tv went blank and started making a clicking noise
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 01, 2014 | Proscan PLED4274A 42" LED TV 1920x1080, 60...
No picture
It's obvious that the power supply failed. The most common parts in a power supply are a thermistor or a voltage rectifier, possibly even a voltage regulator. diodes or resistors can act as fuses too. A ringing sound can come from a fixed coil that isn't kept still with enough epoxy. Hope this helps.
Nov 26, 2013 | LG 50PS60 50 in. Plasma HDTV
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an...
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Jan 17, 2011 | Mitsubishi WD-57733 57" HDTV
No picture or sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is XL2100 you can find it here:http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
May 03, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Tv wont turn on
it sounds to me a transformer in your set has gone hard to say witch. im guessing it is a CRT set the best thing i could suggest would be to take it to your local tv repair shop they should be able to sort this for you and it shouldn't be to expensive.
Mar 10, 2009 | RCA 27V514T 27" TV
RCA P46130 no picture
i tried unplugging mine when the picture went out. i left it unplugged for about 10 to 15 minutes. still no picture
Jan 10, 2008 | Philips 50P8341 50" Rear Projection...
No sound or picture
What is your model number
Jan 08, 2008 | Televison & Video
Samsung TXM3296HF problem - tv won't turn on
your flyback transformer could be your problem or in the video circuit.have a tech look at your tv for possible repairs.good luck.
Apr 01, 2007 | Samsung TXM3296HF 32" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
274 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
