Question about Sony NWZ-S615F Walkman Video MP3 Player
Networking Trouble? I've had my mp3 player since January. And as of these last few weeks, I've had to struggle to charge my device. Now, my device won't even charge in the slightest. What's happening? What can I do? Please help! Thank you for your time.
  • alessdrine_b Sep 14, 2008
    Thanks so much for your quick response and you'll have to forgive me for my bluntness, but, it didn't help any. I have a feeling that it's my actual USb chord and not the machine...I don't know...but thank you anyway for your help. I greatly appreciate it.
  • 8,596 Answers
Make sure you are using the USB cable that originally came with the Walkman. Make sure the hold switch is not turned on.
Reset the player.
Try charging using another USB port on your computer - if that fails, try charging on another computer completely (but make sure it has the same OS or you will experience formatting- related issues).
My general info sheet: 1.       “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE)
The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Many laptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button.  There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard.
Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue.
If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this.
Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.”
If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components.
If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced.
-Tha Mp3 Doctor
Posted on Sep 14, 2008
Ipod not charging
Hi,Here is the solution to your problem;its easy ,go to device manager and delete all the usb devices then goto control panel and delete ipod, but not itunes that way you will still have your songs and playlists, then reinstall the device if it works then well done i had that before and that worked for me, if not get a new battery there not that good on the ipod dont last long so get a new one and see what happens
good luck
Jun 03, 2010 | Apple iPod MA446LL/A MP3 Player
My 4GB version is freezing my computer screen when hooked up
  • Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
  • Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds.
Dec 06, 2009 | Insignia NS-DV2G MP3 Player
One day I got in trouble my dad took it away. Once I get it back a week or two later I put it on my moms laptop to charge but no computers are detecting the device or it wont charge. Can you help me to fix...
first off check the cable your using it might have gotten broken then check the mp3 player and see if theres anything blocking or wrong with the mp3 players charging port
Sep 25, 2009 | SanDisk Sansa e250 MP3 Player
USB device does not work
Purchase a usb power plug to plug your device into the wall if it charges then your computer just needs to re install the device driver
Aug 29, 2009 | Sony NWZ-A816 Digital Media Player
Charging trouble
Might be a bad battery.
Feb 09, 2009 | Insignia NS-DV2G MP3 Player
I plug my mp3 player into the computer to charge and it turns off
Run a repair in the Philips Device Manager - make sure the lock switch is disengaged first.
-Tha Mp3 Doctor
Nov 25, 2008 | Philips SA3125\02 MP3 Player
Battery life
Dependable, Ive only had mine a few weeks (it was a gift) and its unpredictable to say the least after the 1st charge it lasted about 10hrs and its slowly depreciating! im averageing about 3 hours now.
Aug 07, 2008 | iLO MP3 Player
I have a phillips mp3 player sa6185/02, since last week when | down loaded some music onto the player, I have experienced a problem. When I turn on the mp3 player and go into my music option my play...
Before you send the player off to Philips, try the repair procedure.
Make sure you have Philips Device Manager installed on your PC, and open it.
Press and hold [VOL+] whilst connecting the player to the PC.
Device Manager will report an error with your device.
Follow the on-screen prompts.
NOTE: ALL DEVICE CONTENT WILL BE DELETED.
If the player still doesn't connect then roll-back all of your USB drivers.
Jun 21, 2008 | Audio Players & Recorders
Charging problem/malfunction
Firmware upgrade from Creative's website to permanently resolve
Temporary:
Reformat the player
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 30, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen MicroPhoto (8GB) possible faulty USB Cable ????
When I had that problem on my Zen I un-installed all the software and rebooted my system and reloaded the software. Not sure why it worked but it did.
Nov 13, 2006 | Creative Labs Zen MicroPhoto MP3 Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
88 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
