Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer smell of gas inside and venting
My Maytag LDG8624 gas dryer works fine; dries clothes great. I just puts a strong smell of natural gas outside where it vents and when you open the dryer while running. If you open the dryer after it has sat for a while, there is no gas smell inside. The gas company tested and confirmed there was gas in the dryer but nothing on the exterior and connections. Is this dangerous? How can it be a gas leak inside the dryer if it is still drying? HELP. They only have electric dryers in stock in my area and my wife can't wait the 3 days for them to get a new one in stock.
  • 1 more comment
  • reevtd Sep 14, 2008
    Let me also add that the vent is brand new, and it is very clearly venting outside with a strong volume of air flow.
    Thanks,
    travis
  • reevtd Sep 18, 2008
    Thanks for replying, but you didn't address the issue of a natural gas presence in the dryer and the strong odor of gas outside coming from the exhaust vent. It isn't just a smell of clean air; it is the strong odor of natural gas.
  • Anonymous Mar 12, 2014
    2012 Maytag Bravos gas dryer gives off burn smell while running
  • 943 Answers
Hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Posted on Sep 18, 2008
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
The clothes are dry but have a smell of natural gas
I think your exhaust hose is clogged. Please make sure it is completely free of lint. Remembver to check the outside vent.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
GE Dryer has gas smell inside.
i would not play with this problem , the lines and the seals in the dryer must be checked .. by a proffesional ... hope u dont get a spark , get this checked imediatley
Sep 26, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Eric
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Burning smell during drying cycle, coming from the inside back left grate. The grate appears discolored.
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat . If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Jul 11, 2009 | Whirlpool WGD6200S Gas Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Jan 18, 2006 | AEG T57800 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,485 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
