Question about RCA F32450 32" TV
Lost my picture
I turned the tv on and shortly after I heard a pop and lost the picture. This happened to me before on a 27" sharp. To fix the sharp the tech had to replace the horz. control. I fell it's the same thing this time around. Your thoughts please? I do a lot circuit repair on pc's and consoles, just not tv's. So I feel confident that I can fix this problem if I knew what/where to repair/replace. Basicly if you can tell where to do a continuity/Ohm check and what the rating is, would be very helpful. Also how can I get a digital copy of the schematics for this model. The tv is an RCA 32" M# F32450 CH# ACT113CA1 Thanks RDTownsend75
  • Rob Townsend Jun 23, 2006
    Techman, Thanks for the quick response on the post.
    I did some checking on the flyback, I felt I had results that warrant a replacement. I picked one up at surburban for $20, installed it and bam, still no picture. As before I have sound but no picture. I have the pdf of the schematics. As far as I can tell the schem. point TL02 as the Hortz output. I looked up the grid and I see TL02 as a heat resistor attached to an alum. sink.
    So now I'm lost for ideas, or just plain lost. Tell me how you want me to get this pdf to you. Please take a look for yourself and tell me what you think.
    Thanks Again
  • Rob Townsend Jun 24, 2006
    Looking at board #PCB EW ATC113. I see two transistors, #1 TL81 (signal transistor)?, #2 TL82 (output Transistor). TL82 has some discoloring on both sides of the printed board. I would think this is expected with use and time. Is LL81 the small coil you are refering to? As for removing, cleaning and resoldering. Also on this board there is a Capacitor at CL85 that I do not get a reading from, however I have not done a charge/discharge test on it yet. I'll wait for your response before I continue my headache of a tv. lol I added a picture for your viewing pleasures.
    President:
  • 3,130 Answers
This modelis avail on a PDF file from Sams photo facts for $27.50. First thing you wanna do is disconnct the horizontal output transistor.. Measure the base to collector or emitter to collector for a short. If it is shorted then the high voltage transformer(flyback xformer) is the reason it is bad. Its part # is 257805 and cost about 40 bucks at most RCA parts houses Also these models a small coil can cause the horizontal to blow out and its the small coil that conects the horizontal output transistor's base to the horizontal output tranformer secondary winding. Sart there first if you dont get anywhere please contact us again and post the pdf and we will look and ask you to do more checks. Good Luck
Posted on May 28, 2006
  • Larry  Dillon
    Larry Dillon Jun 23, 2006
    Ok Sir you need to also check the small coil off the horizontal driver transformer secondary going to the base of the horizontal output transistor. You have to taker it out and scrap the leads and resolder it. Also make sure the Horizontal output transistor is not shorted out of the circuit. I never heard of this transformer only costing 20 bucks??? yea it maybe a good Idea to send me a copy of the PDF if you dont mind But they dont allow PDFs here let me get in touch with the ops and see what they can do for us??. hang tight man were gonna fix this sucka!!!
  • Larry  Dillon
    Larry Dillon Jun 24, 2006
    the coil I was refuring to is marked LL04, the transistors to check would beTL502,TL01, and TL02. Make sure the resistor marked RL05 a 2k resistor is good too.
Heard a pop coming from tv, no picture but do have sound.
Power supply board has lost a component, most likely a capacitor.
Oct 19, 2014 | Televison & Video
My tv lost the picture but the sound was working. i then turned the tv off then on. nothing happened. the red light flashes to green then to red with no clicks and or no sounds. i wasnt in the room at the...
I had the "pop" happen to me about a month ago. Sounds like the same symptoms as you list. I searched online to find the most common fix to the the Y Sustain board. You can find this part online for about $150. I have used rivervalleyelectronics.net. Ultimately, I chose not to fix my tv and bought a new one. Before trashing the TV I removed all the boards and have them available for sale if you are interested. I will sell all the boards, including speakers and cooling fans for $150 plus shipping. Contact me if interested.
Sep 28, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
My plasma tv has just lost it's picture. I do have
There will be a fault in either the Y or Z sustain boards, these are responsible for driving the screen 9hence sound but no picture). The popping sound willhave either been a fuse blowing on the board or another possibility is one of the drive ICs on the buffer board has blown. If so it's best to replace the board.
Mar 21, 2010 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Televion was purchased in 2002 picture was sharp
Need more information.
Are you connected to an antenna?
Did the stations in your area go digital? (DTV converter required)
Mar 02, 2009 | JVC AV-27530 27" TV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Screan turned a shade of purple
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
Nov 21, 2008 | RCA Televison & Video
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Tv popped and stopped
The over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. It's best to have a Certified TV repairman look at it. Generally when this happens, the TV keeps getting worse and repairs can get expensive. If the repairs are over $300, then I would look into buying a new set.
Jul 12, 2007 | Orion STV2763 27" TV
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
RCA F32450 32" TV Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
