Re: What do i do when my ac adapter from my xbox 360...
Your Power Supply has failed, you must replace you power supply. the red light mean there a hardware failure inside the power supply. try to unplug it as it can damage your system.
HI you did not mention is you are able to use the unit even tho the led turns red. If not then the unit is drawing to much current and the power supply is shutting down. Or the power supply is faulty, If you can and know someone with a 360 system try to borrow theirs and see which part of the system is faulty if you know his is good and the same thing happens, or take yours to his house and try, but if same results then the 360 is at fault.
This can actually happen quit a bit but it sounds to me like the usb jack may be dieing or not producing enough power. This can be caused if for instance you use wired controllers. Have you tried using the front usb ports.
this could be the case if you need to replace the ac adapter its called a figer of eight mains lead, but the problem could be somethingElse if you have lots of plugs on one socket this could case a problem with a short surge ruining to the xbox and popping the red button out try using the box on one power point on its own with nothing Else even if this means running an extension cable from the hallway or kitchen, if it pops again then look at the mains lead. if it does not pop is ur power point (plug/s where you have the xbox pluged in). i hope this help cheers
the power supply is already busted
you need to call xbox 18004699269
if you purchased the xbox within 90 days, then they can have your power supply replaced
if not you need to buy a new one
Try moving everything to a different room on a different electrical circuit (as in electric panel outside your house). You might have too much load on that circuit for the plugs in that room. You could try unplugging everything except tv and xbox too.
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
