Question about Frigidaire Dryers
Error code E68 - Frigidaire Dryers
  • 725 Answers
E68 is a stuck button check all button if you can't unstick you will have to replace contol..
Posted on Sep 14, 2008
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
What is Frigidaire gallery dryer code e68
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Feb 13, 2015 | Frigidaire Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
Error code e68
Good Afternoon Friend,
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Error code 68
Good Morning Mua_m7,
I see that you are having trouble with your Frigidaire washer giving you an E68 error code. The E68 could be one or both of two possibilities.
First, it could be the heating element. If the heating element goes out, this means that you would be unable to get the water temperatures to hotter temperatures.
Second, it could be something going on with the main control board inside your washer.
With you receiving the E68 error code, I suggest that you give your washer a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. When you restore the power, if you are still receiving the E68 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire Washing Machines
E68 error code
If it's a Frigidaire, It's a failure of the touchpad control.
Jun 12, 2012 | Washing Machines
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Dec 29, 2010 | Microsoft Xbox 360 Console
Dryers Logo
464 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
