Question about Philips 28PW6006 28" TV
Circlular discolouration on screen
The colours 'blew' on my tv - everything in the centre appears greenish, with a blue ring outside this, and 'normal' colours ponly appear at the very edge of the screen - can this be fixed? Many thanks
  • anrtonia chitty May 29, 2006
    sorry - /i know nothing about how tvs work. the picture just is totally discoloured - everything centrally has a greenish tone
    Antonia
    sorry - I know nothing about how tvs work. the picture just is totally discoloured: see image
    many thanks
    Antonia
    President:
  • 3,130 Answers
Im sorry My friend I dont have a clue what your saying .. I need a picture or more detail as I dont have a clue where to start get back to us.
Posted on May 28, 2006
  • Larry  Dillon
    Larry Dillon May 29, 2006
    is that pic small in size and a black bar running up throu the picture.. Looks loike a power supply problem in the Main B+ filter Im thinking or the regulator IC failed and isent puttimg out as much b+ as it suppose to. This is not a repair that a non pro should get involved with. you should call your local authorized dealer for repair info. Good Luck
Picture is greenish hue and cannot be changed from menu bar
The greenish hue cannot be adjusted from the menu. One has to do it from inside.First confirm by turning the color settings to zero using the remote. You should get a clean black and white image with no traces of any color ( inc: green ). If your TV is greenish , the green drive on the base of the picture tube has to be trimmed.
All you need is a screwdriver. There are dangerous voltages inside a TV, some as high as 27,000 volts !!!. Where the color adjustment has to be done there are voltages as high as 110 volts and 8000 volts.If you still want to make the adjustments yourself revert back for instructions
Apr 11, 2011 | Sony KV-36FS12 36" TV
Discolouration has started to appear in blotches around the centre of my t.v. It started off yellow and now is starting to go blue but the blotches are starting to spread. What should I do?
The light engine of your TV is becoming weak. its is a common problem of 3LCD rear projection TV. You need a repairman to fix this kind of trouble.. The light engine replacement is expensive, It costs like a new TV set.
Nov 08, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
Discolouring of monitor
There are several reasons for this most likely is the vga cable from the video port has undergone stress (sharp bending or crushing) this damages the cables inside and causes one or more of the colors to not display, usually red and or blue. odd it seems the green always is left unharmed when I see this...weird.
If you can I would replace the cable from the monitor to the computer. if the cable is sealed in then you may be able to find a replacement at a service center. and they could replace it for you
Apr 30, 2008 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Daewoo GB2898ST
the problem is in your degausing coil and its circuit. probably it wont start every time you turn on you TV.
Apr 24, 2008 | Televison & Video
Tv discolouration
It sounds like your problem is magnetisation of the crt. Try to switch it on and off for 3 times: on for 1 minute, off for 3minutes, on for 2minutes and off for 5minutes. Then switch on and see if the discolouration dissappeares. IF not, then a technician needs to check the internal degauss circuits.
Jan 24, 2008 | Beko 324250WN 28" TV
Colour stain
Hi.
Yes it is A degause fault caused by either something magnetic being close to tv screen EG hifi speakers.
Or faulty degause thermistor, Or degause thermistor is not making good contact with pcb & only requires resoldering to pcb.
Allso try turning tv completely off at the mains switch leave a few hours then switch back on.
If you decide to take to A repair shop this repair is not expensive.
http://dysonmanuals.inc.io/
Chris..
Nov 21, 2007 | Sony KV-27S10 27" TV
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Philips 28PW6006 28" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
