My house have a gas heating and electric cooling system. When I turned the cooling on the outside fun started but the cooling system inside house does nto start. I tried heating system it dose not start also. Please advise what might be the problem. Thanks
  • 958 Answers
If the fan outside is running then feel the compressor outside or listen to it if you can notice that the compressor is running the same time the outside fan is running also.
it could be that the compressor is not running.
but if you can notice that the compressor is making a different sound as it turn on, then the compressor is running but not cooling, then you could have a leak problem. there is no or little refrigerant in the system.
if you have a leak, please contact your local repair man to do it.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
We have 2 furnaces in our house, both on the braeburn 3200 model thermostats.
If you have a dual fuel system - gas/heat pump the heat pump should lock out at around 41 degrees depending on what the outside lockout sensor is set at. It may be that both the heat pump and furnace could be running at the same time if the outside lockout isn't working or there could be a problem with the thermostat. Best bet would be to have a service tech check it out. However if you want to check it out here are the terminals Terminations: R,Y1,Y2,W2,E,G,O,B,L,C. W2, E and B are the heating terminals for 2nd stage heat and emergency heat. First stage heat, compressor Y1 with B (reversing valve on heat pump) energized together. 2nd stage W2 energized for gas or electric heat . No power to Y1 and B when W2 is energized if gas. E can be energized with Y1 and B if you have electric heat or if you switch over to emergency heat, E will be energized.
Feb 02, 2016 | Heating & Cooling
Tip
How Heat Pumps Work
How on earth can you get hot air or hot water from very cold outside air? How does a heat pump make this heat out of cold air?
When certain gases change their state from a liquid to a gas or from a gas to a liquid the magic happens.
A heat pump can do some pretty amazing things, when it comes to making heat. To understand the way they work, you must first understand what happens when certain gases change from a liquid state to a gas and back to a liquid again. To simplify it a bit we need to look at a basic air conditioning system. The refrigerant in an air conditioning system is changing to a liquid in the outdoor condenser. The compressor compresses the gas forming a hot gas. As this gas cools under high pressure it changes into a liquid form.
Inside the indoor coil the liquid is pushed through a small hole or orifice. When it comes out the other side it rapidly changes it’s state to a gas as the pressure suddenly drops. The rapid pressure drop changes the refrigerant to a very cold gas. Air flowing over the cold gas inside the pipes makes the air cool and provides air conditioning.
Now for a heat pump the process is much the same, only coils are just switched by used a reversing valve in the outdoor condenser unit. Instead of the heat being purged to the outside from the condenser unit, the indoor unit then becomes the condenser coil. The outdoor coil becomes the cold coil and cools the outside. This is why if it is very cold outside the unit will have to run in air conditioning mode for a short time to defrost the outside cold coil. When this happens the system will usually have electric heat inside to run and keep the indoor air warm.
The reality is that a heat pump is really no more than an air conditioner running in reverse. Through the magic of using refrigerants, a heat pump can then run many times more efficiently than straight electric heat. A careful heat loss/gain should always be performed by a qualified service person before any sizing of a unit. Too large or too small of a heat pump system can make it inefficient and possibly cause it to be very uncomfortable. The longevity of the unit can also be affected by sizing and installation. Be patient and look carefully for the best contractor to install your system.
A properly designed and installed heat pump system can give you many years of comfort and efficiency. If you look for and find the contractor that can do the job right you will get many trouble free comfortable years from your heat pump unit.
on Dec 29, 2009 | Heating & Cooling
Is the condenser inside the unit
In a window unit the condenser is in the unit and is at the back of the outside section. With a split system or whole house cooling unit the condenser is always outside. The condenser compresses the cooling gas after it picks up heat from the inside evaporator, and forces the heated gas through a coil with a fan blowing through the coil to drive out the heat. A gas can be compressed, but the amount of heat it contains remains constant. A compressed gas will be hotter than non compressed.
Jul 26, 2015 | Heating & Cooling
How do i get AC to work?
air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
May 26, 2012 | Sunpentown SPT WA-9040DE 9,000 btu Dual...
I have a Mitsubishi air conditioner GA35VA system. 1. HEAT: If outside temp is bellow (aprox.) 16C, no heat is produced. the system starts. The outside compressor starts to work but stops after some...
Your problem is outside, i can see why he would say it is a sensor problem ...But perhaps it is your fan not turning at the correct speed. example if on a really hot day your air conditioning cuts out it could be your pressure is too high which would trip your compressor. What refrigerant does this system use? and is this a new installation? or is it an old installation new problem? Do something for the MUZ-GA35VA external device open the top when u have another failure and on the board there should be a particular type of flashing pattern, that "should" be fairly accurate in diagnosing the problem. Get back to me
Nov 16, 2011 | Mitsubishi Heating & Cooling
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
Gas and electric cool/heat system - heatpump and air conditioners
Hi you takling about geo thermial unless you know about this its hard to tell you what you want to know ,you needto have holes sunk in the ground for collecting the heat that is pumped to the house . they is to omuch to say , the best thing to do is find a company that does this work, its costley but you do get your money back very quick , it is the way to go have done some work on this type of system they work well if done right ....best of luck with your system
May 31, 2009 | Whirlwind FH-778 Air Conditioner
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
