Question about Whirlpool Duet GHW9150P Front Load Washer
Washer issue put washer on pause to add garmet...washer now flashing "Sud" will not start again
  • 5,911 Answers
Unplug the washer for at least 30 minutes. Sometimes this is all that is required to clear momentary glitches with the control board. If that does not correct the problem, the following link explains the "SUD" error:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
Hopefully, this is just a momentary problem and nothing else. The link I provided will give you guidance on what to do if the problem persists. I hope this helps you. Let me know if you still require assistance.
Posted on Sep 14, 2008
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My WP duet washer wont restart after adding a garmet!
Have you tried unplugging the washing machine then start over,this may clear it out and in able you to start fresh.
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
