Question about SanDisk Sansa e200 MP3 Player
I have a SanDisk Sansa m200 mp3 and a macbook pro
I was given a SanDisk Sansa m200 and when I connected it to my macbook pro nothing shows up on the desktop so I don't have anywhere to drag music too. I did not receive any cd or software with mp3. Any suggestions on how to get mp3 to work with macbook pro? Thanks, sara
    Problem Solver:
  • 9 Answers
Even on a Macbook pro, you should be able to access your "my computer" option, where it shows you the local disk drives and everything. your mp3 player icon should appear there. then after you click on the icon it should bring up a page containing folders "on" your mp3 player. there doesnt have to be any music or videos or anything like that to have the folders already on there. now i dont have a mac but what i suggested you to do should work.
Posted on Sep 14, 2008
How to delete songs that are not showing
Try switching USB mode of the player, to see the hidden files.
See next help link:
http://kb.sandisk.com/app/answers/detail/a_id/447
Look in the manual for the m200 series players on page 31 under USB, how to select Auto Dectect (MTP or MSC) or only MSC :
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
MTP is Media Transfer Protocol, seeing the player as a media device.
MSC is Mass Storage Class, seeing the player as a removable disk.
All support for the m200 series players, on next page:
http://kb.sandisk.com/app/answers/detail/a_id/4487#m200
May 19, 2010 | SanDisk Sansa m240 MP3 Player
How can I put music on Sansa MP3 player from Macbook Pro?
Not to sure about a mac but I think mac's use a mp4 format when it rips a cd, and the Sansa will use a mp3 file. You can download a free program to convert these files but again, I know where for a PC but not a mac. Look for free mp4 to mp3 converter program for Mac..
Jan 28, 2010 | SanDisk Sansa m230 MP3 Player
How do I delete existing songs?
Deleting songs can only be done through a connection to a computer.
See the manual for the m200 series player on page 13 + 14 (= 12 + 13) how to delete:
Need more help ? Just post a comment.
Dec 21, 2009 | SanDisk Sansa m240 MP3 Player
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m200 mp3 player problem...
check this out....http://www.anythingbutipod.com/forum/showthread.php?t=20366
Jun 21, 2009 | SanDisk Sansa m200 (2 GB) MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m200 series and my macbook pro
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Where are the songs??
Format your player and reinstall your music.
Aug 22, 2006 | SanDisk Sansa m200 (2 GB) MP3 Player
SanDisk Sansa e200 MP3 Player Logo
287 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
