Question about Roper 24 in. RUD5750DB Built-in Dishwasher
Dishwasher needs repair
There is a piece of the inside of the washer that has come loose and I cannot tell where it belongs. It's a white cylinder shaped piece with a smaller piece sticking out of it. There washer will not dissolve the power now and the dishes are not washing. please advise.
  • bonnie hall May 28, 2006
    I think the white thing may be the hub cap for the sprayer arms. does anyone know how to replace it?
  • Anonymous Apr 28, 2008
    Bonnie, I believe that is the cleaner for the holes in the sprayer arm. You manually insert the small end into holes and move in and out. It stores when not being used, in the front bottom near the door. Jere
    President:
  • 878 Answers
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
Posted on May 28, 2006
SOURCE:
Why will my ge profile dishwasher not drain?
Inside the dishwasher to the front left is a small round cylinder and inside that white cover is a small floater that is activated electronically and sometimes they will go out and cause the water not to drain. the part is cheap and worth changing out before you call for repairs.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Apr 27, 2014 | GE Dishwashers
HP camera piece fell off when trying to open it. Where does it belong?
U are in deep doo doo because if your unit is out of warranty HP will not do squat for you!
Apr 30, 2017 | HP Photosmart M537 Digital Camera
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Oct 06, 2010 | GE Dishwashers
Two grey plastic pieces came loose. Don't know where they belong inside the dishwasher?They are both the same. They apparently hook onto something on the rack, but I don't have a clue?
If these two grey pieces are about 1 1/2" long and a 1/2" wide. They are used to retain the upper rack onto the tracks to prent the rack from falling out and used as a rack stopper. There are two on the front and two on the back of the top rack. How to insert them may differ dependant on the model. look at the two still attached and you may be able to re-install them.
Aug 29, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Hotpoint HDA3230Z02WW Dishwasher leak
Hello ajs10172003
Welcome
You said, you have a leak under my dishwasher every time you run a load but can not tell where it is coming from. When you looked under the dishwasher it appeared to be leaking under a white cylinder shaped part. This is where the water was gathering at. Not sure what this is. Maybe someone can shed some light on this.
It is probably the SOLENOID that is leaking.
This opens and closes to control the water coming in and going out!
And it looks like cylinder as you described.
Time to replace that part if this is the case. An easy repair only a $40 part.
call service!
Let me know how it goes!
Huuum,
Please remember to leave a rating!
Oct 20, 2008 | Dishwashers
GE Nautilus wont start
check the two switches under the inside cover of the door. there are two switches under the flimsy metal switch actuator, one switch has a black wire in both ends the other switch should have two white or white/red strip wires on one end and one white or white/red wire on the other end. the black wire is power the white wire is your neutral. both switches should have a button in the middle that is pushed in by the flimsy metal switch actuator when you lock the door shut. i had to replace the switch for my neutral when mine quit working. you can remove this switch and get the part number off of it. you can look it up on line or call a small appliance repair store to see if they have the part or can order it for you. remember to unplug the dishwasher before you remove the the inside cover of the door. hope this helps. Sparky TJ
Aug 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Jan 10, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
A part fell off inside the dishwasher
cheapest way is to go into appliance shops and look at other washers that are similar. note how theirs is assembled.
Sep 18, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
208 people viewed this question
Top Roper Dishwashers Experts
Mike
Kevin
Kevin
paul
paul
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
