Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a model KSBP25INSS00. The divider between the refrigerator and the freezer is getting very hot on the front leading edge. The temperatures are floating above the default settings. I have replaced the fan that blows on the condenser and cleaned the coils. The problem has not gone away. Currently I have an external fan blowing in the front grill and that keeps the unit operating properly. Ted
  • 4 more comments
  • tpalango Sep 09, 2011
    I have blown everything off with an air hose. Everything is as clean as can be. Right now the freezer temp is 6 degrees, the recommended temp is zero. It won't get there. I can only get to the recommended temperatures by putting an external fan blowing on the front grill.
    Ted
    Ted
  • tpalango Sep 12, 2011
    Your solution is get a technician out to fix my refrigerator. That is what I was going to do before I contacted you. I feel like I wasted $15 and two days.
    Ted Palango
    The new fan motor is not turning.
    Ted
  • Steven Wayne
    Steven Wayne Jul 17, 2018
    Did you ever get this issue resolved? If so, what was the problem? I have the same refrigerator and it's doing the same thing. Steven
  • 1,998 Answers
Hello ted, I see that you have replaced the compressor fan motor and you have assured as well that the fan is working correct? In all actuality it is best to put the outside fan source around the rear of the machine to blow directly on the compressor itself. Questions for you how fast is the new compressor fan motor spining does it look like it is working properly or is it spining slowly? If the fan were spining properly then you would look at an issue most likely with the condensor where you would most likely have a clog in the condensor itself. You would have to call for a technician to come to your house and replace the condensor. I will await your reply Thanks
Rick
p.s you could also have a clogged capilary line as well which would also cause this as well where the oil from the compressor is not able to move to cool so instead it just heats up due to a blockage in either the capilary, the condensor, or one of the lines. This usually happens from the compressor fan motor not cooling and the unit running and not being able to cool.
Posted on Sep 09, 2011
  • 1 more comment
  • Rick Ead
    Rick Ead Sep 12, 2011
    That would depend on if you had a refrigeration license and were able to cut the refrigerant line and have an evacuation pump and an evacuation tank ready and available to remove the refrigerant out of the unit. You also have not responded to if the evaporator fan motor was spining at the proper speed nor answered any other question that I purposed. We arent able to see the unit that is in question. I will await your reply once again Thanks Rick
  • Rick Ead
    Rick Ead Sep 13, 2011
    Sorry it took me a bit ted just returned off the road last service appointment was 75 miles away. If the fan is not turning check the wiring with a multimeter to see if you have power going to the fan if you dont you can trace the wire right back to the board. Make sure you check for any breaks or burn out spots in the wire. Your main control board is located in the ceiling of the refrigerator as seen on this link http://www.searspartsdirect.com/partsdir... part number 6 is your main control board. I will await if you have any other questions and to your finds as well Thanks Rick
    p.s please also note I do run two appliance repair companies but I do answer all customers questions daily and I am also on nightly as well. Thanks Rick
  • Rick Ead
    Ted also check that the fan is able to spin as well if you did not hook the new fan in properly and it has to sit exactly in the right spot then the fan blade wont spin the motor would heat for the compressor fan motor and eventually short out due to being to hot. I await your reply Thanks Rick
    p.s when you hooked the new compressor fan motor up and installed the new one was it working? You can actually bench test the fan motor by removeing it then takeing a extension cord cutting off the female end and adding two electrical connectors then plug the two electrical connectors to the two connection points and plug the other end into the wall. By doing this it would make the compressor fan motor run and as I have found out time and time again when ordering new parts defective parts are not uncommon causes me to test everything. I await your reply Thanks Rick
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Condenser lines that are getting exceptionally hot can indicate a condenser that is covered with lint and preventing proper air circulation.
You can remove the bottom grill and check if the condenser is clogged with lint.
The area around the panels do normally get hot and as long as the condenser is clear and air is circulating then most likely this is normal.
SOURCE:
Overheating
The fan you should be checking is behind unit , under a cardboard cover , its the condensor fan motor, desined to disapate heat in that section.
Mar 30, 2014 | Kenmore 53642 / 53644 Side by Side...
Front edge of fridge cabinet gets exceedingly hot...too hot to touch!
condensor coil is clogged up, or condensor fan is not running.
Dec 04, 2012 | Refrigerators
Can any1 tell me why the divider between freezer n fridge is getting hot at front on my Samsung rs21dcns, and is it an easy fix? Thanks very much
The warm feeling around the doors is normal... they have either a very small heat element inside there, or the discharge line is routed through there, which is to preventcondensation from forming around the edges of the door. If it has an "energy saver" switch inside near the thermostat, turning this switch to the energy saver position turns off the heaters around the door edges, but may cause condensation to form if the humidity level inside the house is high.
Nov 02, 2012 | Refrigerators
Center Divider VERY hot...
The center divider gets very hot , when the fan motor that cools the compressor stops or the coils at the front bottom , gets clogged with dust , lint , pet hair , etc . Check the coils to make sure they are clean . Next , pull the refrig out from the wall , and remove the bottom panel . Check that the fan is working and that nothing is blocking the fan blade , cooling the compressor and coils .
Oct 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Side by side. Front edge of divider between fridg
There is a heater there that reduces condensation. If you have a switch that has energy saver mode, that would turn it off
Sep 04, 2009 | Refrigerators
Magnetic divider strip is hot. Temperature not cold enough
Yes this is normal. The heat strip is there to prevent moisture from forming around the the door frames. It also is most noticeable if the heat wave is causing your refrigerator to struggle to cool. Cleaning the coil below the refrigerator and making sure good air circulation in that area will help. If you have any questions please let me know and visit my siites. Please rate me if this was helpful, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Jul 30, 2009 | Whirlpool Refrigerators
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Heat build-up
Had this same problem and turned out that the coils at back of fridge and below doors were covered in dog hair. After vacuuming, area is no longer warm.
Aug 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
612 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
