Question about Philips Magnavox 51MP392H Rear Projection Television
Help. Please, TV won't come on.
When I push the power button the light flashes, the TV Chirps and goes off, It then repeats this over and over until the power cord is unplugged. I need to know what parts to buy to make this repair , where I can buy them and if they are plug in parts or if they will have to be soldered to one of the boards. Thanks Bassnut_22
  • bassnut_22 Sep 14, 2008
    posted by Mendonca on Aug 12, 2008
    Report abuse
    The chirping is more like a cricket and is 17 chips at 10 seconds. There is no smoke or smell. Sounds like its coming from the bottom right side of the tv (looking from the back) and the only light that comes on is the light in the power switch.
    Comment by Mendonca, posted on Aug 19, 2008
    If I purchase the convergence amps (7044 and 7045) will I be able to tell where they go if I don't have a schematic for my 51PW9303?
    if(typeof LIB_LOADED == 'undefined'){document.write(''); }
    Solve This! Post Solution
    Work Queue
    --> Have the same problem?
    I have the same problem
    -->I have the same problem.
    X
    This Problem has been added to the Share Your Expertise Page under "My Work Queue".
    OK
    Solution #1
    Lawrence1974
    Rank: Wiz
    Rating: 79%, 31 votes
    Replace the defective Convergence
    Amps (7044 and 7045) on Small Signal Module.
    932212344682
    Comment by Lawrence1974, posted on Aug 19, 2008
    When the Convergence Ampa go out the set willmake a chirping sound and the set will not come on.Also the HVG (5904) 312226832865 could be defective also that will be the only 2 reasons for the set not working.
    There are no instrutions on replacing the baord it is easy just make sure the set is unpluuged. Put it together the same way you will take it out.If you came do a computer this should be a piece of cake.
    Shuttle83
    This sounds like the same problem that I'm having, could it be the convergence Amps? Not doubting your solution just wondered if there was any chance that this could be it. Thanks Bassnut_22 Work Queue --> Have the same problem? --> I have the same problem -->I have the same problem.
    X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Aug 19, 2008
    Lawrence1974
    Rank: Wiz
    932212344682
    Comment by Lawrence1974, posted on Aug 19, 2008 When the Convergence Ampa go out the set willmake a chirping sound and the set will not come on.Also the HVG (5904) 312226832865 could be defective also that will be the only 2 reasons for the set not working. Comment by Lawrence1974, posted on Aug 19, 2008 There are no instrutions on replacing the baord it is easy just make sure the set is unpluuged. Put it together the same way you will take it out.If you came do a computer this should be a piece of cake. Shuttle83 This sounds like the same problem that I'm having, could it be the convergence Amps? Not doubting your solution just wondered if there was any chance that this could be it. Thanks Bassnut_22
    Genius:
  • 1,139 Answers
Hello bassnut_22,
This sounds like a power supply problem. 9 times out of 10 you are dealing with soldered components. Now for the bad news, you are not going to solve this problem by just getting the parts that you need as easy as you think, any number of things can be wrong with tis TV. First I would check the Horizontal Output Transistor to see if it is shorted to ground (check the collector in reference to ground), also I would advise checking the Integrated High Voltage Transformer (voltage output test, resistance test, capacitance test and ring test). The tests of the IHVT will tell you if the transformer is bad and in need of replacement. These are the first checks you will need to do.
Thank you,
I hope this Helps,
Shuttle83
Posted on Sep 14, 2008
  • Henry McKelvey
    Henry McKelvey Sep 18, 2008
    Hello bassnut_22,
    This could be a factor, in that the amps could be shorted out as opposed to open. However I would suspect that before your tv went out you would have experienced the typical rainbow wave problem that is associated with the convergence amps going bad. That is why I am hesitant about blanket statements without troubleshooting a problem. That's why I always say to check the circuits out first by using a schematic and a multimeter. Yes the amps could be the problem, if they are effecting the power supply's ability to start the TV due to activating the shutdown circuit. However I would also check the HV power supply for damage, since that is the more likely scenario.
    I hope this helps,
    Shuttle83
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
Key chain button
need which button?
can you explain the problem in detail?
Oct 06, 2008 | Car Audio & Video
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
I have a 2005 Honda Odyssey Touring. I bought it used last year, so I am not too familiar with the car alarm in it. The alarm was fine until my battery died a few months ago. After the car was jumped, the...
Ok, try this.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
Dec 21, 2010 | Honda Vehicle Parts & Accessories
The battery was left off of my 02 ranger and now the anti theift is not working..I only have one key How can I reset the anti theift with one key???????????
Put the key in the ignition, and turn forward all the way just before cranking. Then within 5 seconds, locate, press and hold in the valet/overide button, found under the dash area, (push button, spring loaded) until the installed LED (the blinking light) in your dash area goes on solid, and the siren chirps once.
(Your valet switch might be the toggle (on/off) type. in this case, key on, flip switch in opposite direction, then turn the key off.)
This should reset the alarm, and reset the grounded relay on the starter wire, allowing you to start the engine.
At this point, the only thing working would be the keyless entry from the alarm, if it came equipped that way.
Just Repeat these steps to place it back to usable armed mode. You may get 2 chirps, confirming it, and the lights may flash twice as well.
That should do it.
Dec 11, 2010 | Ford Ranger Cars & Trucks
Anti theft system lock down need to unlock...it locked up the computer is shut down and dont start is there a solution its a 2001 Ford Ranger XLT 4X4 4dr
did you try both keys? also are they the originals that came with it new? if not inferior keys go bad all the time
May 11, 2010 | 2001 Ford Ranger Regular Cab
ANTI THEFT LIGHT KEEPS FLASHING ON AND OFF
Did you steal it? I heard about you thieves who steal cars then put new transmissions in!!
Seriously, try this, it may help...
Put the key in the ignition, and turn forward all the way just before cranking. Then within 5 seconds, locate, press and hold in the valet/overide button, found under the dash area, (push button, spring loaded) until the installed LED (the blinking light) in your dash area goes on solid, and the siren chirps once. (Your valet switch might be the toggle (on/off) type. in this case, key on, flip switch in opposite direction, then turn the key off.) This should reset the alarm, and reset the grounded relay on the starter wire, allowing you to start the engine. At this point, the only thing working would be the keyless entry from the alarm, if it came equipped that way. Just Repeat these steps to place it back to usable armed mode. You may get 2 chirps, confirming it, and the lights may flash twice as well. That should do it. Check out www.explorerforum.com
Dec 04, 2009 | 1996 Ford Explorer
Sony kv-32fs13 chirps and flashes
Hello 0279737,
This problem is caused by a shorted Horizontal Output Transistor. I would suggest that you have this TV checked by a qualified TV technician. This type of problem requires dealing with dangerous voltages, and repair should only be attempted by a trained technician.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Oct 28, 2008 | Sony KV-32FS13 TV
Technika tt- 706 universal 2 in 1 remote
turn the tv on. hold tv and set buttons untill the power button flashes. point the remot at the tv untill the tv turns its self off. press any button on the remote. turn the tv back on and test it.
Oct 10, 2007 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
