Question about Apple 64MB NVidia NV-11 Video Card for PowerMac G4 Cube 450&500Mhz Video Card (p/n 661-2461) Graphic Card
Monitor does not come on
I have a powermac g4. it worked fine until a week ago. when i turned it on the monitor did not show anything. tested the monitor on another computer ad it works fine.
is my video card bad?
  • Keanu Burke
    Keanu Burke May 11, 2010
    what make is your video card?
  • 51 Answers
The video card you used may work for the 2nd computer but not for the 1st because of the system requirements. They might be different simply because they are different models. check which video card is RECOMMENDED, NOT MINIMUM, and get the recommended video card.
However, if it is the right video card, then get it checked at a pc shop, like pcworld or somewhere like that and see what they think of it.
Posted on Sep 14, 2008
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
Powermac g4 shut down
OK it's a G4 iMac.
Burning smells coming from macs often indicate a failure in the power supply module. That said, the G4 iMac (in my experience) has been the most reliable iMac ever and power module failures are very rare.
Your best option is to find a Mac repair centre near you and take in in for a quote. But be warned - it will cost. For some reason known only to Apple power supply modules are expensive (but not as expensive as the equivalent volume of HP ink) and replacing them is not as easy as on many of the other computers.
If it is the power supply, you will not be able to switch it on again. Your data on the HD should be safe (unless the smell was coming from that - - I've had it happen!). So when you get to the workshop and you've had your quote, if you decide not to go ahead with the repair, ask the workshop to remove your HD and put it into an external case so that you can plug it in to another Mac and continue using it.
Let us know what the outcome is.
Oct 07, 2009 | Quicksilver Power Mac G4 (Quicksilver)
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
My powermac g4 starts up but none of the icons show on the screen. the search icon appears in the top right hand corner but the computer is not responsive to anything. took out each ram stick and restarted...
Restart in safe mode by holding the shift key strait after the chime untill the apple logo apears. You will have to log in with password. then open **** utillities and repair disk permissions. reboot and it should come back as normal
Apr 25, 2009 | Apple Computers & Internet
DVI connection to DVI port on PowerMac G4
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Rifaa
Aug 02, 2008 | Acer X193W LCD Monitor
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
Richard
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
Unexpected Error (1001)
I have exactly the same problem, only my Deskjet is HP 3840 and I am running a PowerMac G4 with OS 10.4.10.
Dec 11, 2007 | HP DeskJet 5550 InkJet Printer
Apple 64MB NVidia NV-11 Video Card for PowerMac G4 Cube 450&500Mhz Video Card (p/n 661-2461) Graphic Card Logo
378 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
