My camcorder will not take power from the batteries. They are new and charged. It will turn on if the camcorder is attached to the power adapter. I have two camcorders doing this. I have tried the reset button, and nothing works. Anyone have ideas, or suggestions on what to do?
Check for corrosion on the battery contacts, If you find some clean it using a pencil eraser.
Otherwise you're looking at an internal malfunction that prevents the cam to draw power from the batteries. Some transistor needs replacing, if you can get to a lab that has experience working on these, shouldn't be too expensive.
Good luck
Comments:
May 31, 2006
- The point is that the wrong lab might milk you, not one that lives off this and has a reputation for working on camcorders.
There is an internal chemical fuse which opens when there is a problem with the battery. If you are using a generic A/C adaptor, this is the cause of the problem. The A/C adaptor provides enough current to operate the camera but fails in this regard when you're charging the battery on the camera. We see many of these cameras with this problem caused by safety fuse being open. This is not a serious problem and can be resolved by replacement of the battery safety fuse. This is a surface mount device and must be replaced by an experienced technician. Hope this helps you.
Our Pro HD camera is occasionaly giving a 'record error' message and then flipping straight to...
(More)
Our Pro HD camera is occasionaly giving a 'record error' message and then flipping straight to 'media recovery push ok'. THis will 'save' the recorded video but there is no knowing when this happens. What might the problem be? It is not specific to slot on camera or card in camera either.
