Samsung SyncMaster 551  15" CRT Monitor
Problem for Samsung SyncMaster 551 (White) 15" CRT Monitor
Redless screen
By russell on May 28, 2006
the color red is totally missing from my monitor.at times the red returns for a short while then disappears.also there are some parallel horizontal white line on upper side of the screen noticeable whwn the background is black.
i have changed the configuration of video card.no result.
i have replaced the video card.no result.
Same Problem
Oct 28, 2008
-   The color red is missing from my monitor -   Guest
Jun 13, 2008
-   The display of my monitor was totally red. I tried to turn it off for a moment it comes back normally but in a shortwhile it returns again to the same problem. What shall I do with this?
-   edjan
May 09, 2008
-   i have no green color on my monitor, and i dont want to have to take it in to be fixed, how do i fix it myself? Is there a chance i could make it worse?-   tinamoggo
Apr 14, 2008
-   Compaq 5500 CRT monitor, Reinstalled the Drivers still the Red colour is missging and black is there instead of it-   Guest
Jan 21, 2008
-   i need the toll free numder to g2g gear-   Guest
Best Solution
posted on May 31, 2006
Very Helpful)
techman
Rank: Guru  Samsung Expert
Rating: 86%, 7687 votes
Sillygirl I thought I would pass along a little tip on crt testing I learned many years ago. You take a 470 Ohm resistor and ground on end with a cliplead and touch the other end to the collector of the drive transistor. If the crt is good it will glow that color of the drive xixtor so you can simply check all three guns in a easy fashion without draging out the old crt tester/rejuvenator. Now this is only to see if the tube is working on that gun and wont tell you how much gain the color has..
Was this helpful?
Yes
No
Solution #2
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3631 votes
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's and CRT monitors are very hazardous to service. Even when plugged out, they can store very high, deadly voltages.
How old is the picture tube? If there's lots of phosphor burn on it, chances are the red gun inside the picture tube is out.
A sure-fire way requires an oscilloscope. Check the voltages on the three color guns at their corresponding pins on the CRT's neck board.
You can see their levels change as you tweak their adjustment pots on the neck board. If the red voltage is present and at the same levels as green and blue, then the gun inside the tube is shot. If the red voltage is NOT there, then you can work backwards and find out where you're losing it.
It could be a bad buffer amplifier (transistor or I.C.), bad solder
joint, or even a broken wire in the cable harness.
check for cracked solder joints where the RGB, Grd Sync connector is.
check the pins on the molex power supply connector, could be that the pin for the red is pushed back and is not making contact.
Try swapping the red and green inputs if you see red on your monitor and no green, then it is NOT the tube. If you see no red still but still get a green where red should be I would suspect a bad chassis.
Comments:
Jun 01, 2006
- Thanks techman
Preserve the legacy ;]
Was this helpful?
Yes
No
Solution #3
Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1903 votes
The white lines on the darker backgrounds are more than likely retrace lines. Usually caused by a leaky capacitor in the horizontal sync circuitry.
If the red comes and goes it's probably a dry joint in the red drive. If you're handy with a soldering iron try resoldering the solder joints on the CRT neck board. If that doesn't do the trick then perhaps the drive transistors are on the motherboard. Just look for 3 transistors usually in a row and somewhere very close would be adjustable pots with the letters R.G and B printed near them. Even a simple gentle tapping with a plastic end of a screwdriver around that area may make the red flash on and off.
Just resolder around that area and you'll know it's fixed when the red stays on. Just make sure the power is unplugged when working on the set and stay well away from the EHT and power supply areas. They can give you a nasty shock even if it is unplugged. Actually with live chassis TVs it's always best to use an isolation tranformer.
If any of this is over your head the say hello to the repairman :-)
BMW
Was this helpful?
Yes
No
Solution #4
posted on Apr 10, 2008
Not Rated)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
EL" DEMOnYeTO
Popular Solutions for Samsung SyncMaster 551 15"
Questions and Unsolved Problems for Samsung SyncMaster 551 15"
Do you recommend Samsung SyncMaster 551 (White) 15" CRT Monitor?
Answer
Answer
samsung 15 inch crt monitor. After swithed on FBT didn't work
Answer
My SyncMaster 551 (White) 15" CRT Monitor suddenly pop up menu and can't be turn off...need...
Answer
Hi!! Can you please help me with my problem??? I cannot access the control panel of my monitor... (More)
Answer
Well the title says it all. I bought spore just not ... And my PC display just isnt centered........ (More)
6 Other Users Have The Same Problem - Continued
Comment by manofhalhand, posted on Nov 13, 2007
all red images look black
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
