I have a JBL 125SAT system and three of the five speakers have little to no volume. I know the wiring is good but how do I fix the speakers?
  • 3 more comments
  • Anonymous Oct 26, 2008
    2 of my 5 dont have sound but i ust thought they were just the surround speakers
  • drw313 Nov 22, 2008
    i have the same problem but cant seem to find a answer any where. please help if you can
  • Anonymous Dec 01, 2008
    we also 2 out off 5 nearly no volume
  • jcan66 Dec 03, 2008
    I have the same system. Can't figure it out but two of the speakers have very little sound. Please share solution.
  • Anonymous Jan 11, 2009
    xjl;khkj
  • 2427 Answers
SOURCE: My Yamaha RX-497 bought 3
damaged yes... fix yes,, well hopefully,, ok frstly it seems you blew an output IC or a filter.. now i dont have a diagram and basically one isnt needed,, you will need some screw drivers, a soldering iron and some solder..and a multimeter if you have one..
  1. open up the unt (unplug it first)
  2. look at where the speaker's connect you will notice it leads to 4 - 8 huge IC's on heat sinks.. close to the heat sinks are a few capacitors (filters) look at them and pray you find one with an oily surface.. If so remove it by soldering it, take it to the shop and get a new one to solder in place.. and then test the system to make sure it works..
  3. IF not a filter then plug in and turn on the unit.. touch every one of the 4 -8 ic's to see which get HOT!!!!!! very hot,, that one is blown (actually will be more than one) again unsolder them,, get replacements and reassemble..
  4. turn on and enjoy!!..
Posted on Sep 17, 2010
glenmann62
  • 91 Answers
SOURCE: No sound in 2 of my 5 JBL sat125a speakers
check your speakers on another source to cancell out if it,s truly the speakers , if not then you could be in stereo mode which would explain the three front speakers ,mains and center working! other then that unplug and reset ,and if not that then their is an internal amp issue with your system , hopefully you can get it working ,if not check your warranty and see if the manufacturer will repair or replace for you , hope i was able to help you ,please leave a nice rating if i was of help thank you Sincerely glenn mayer
Posted on Mar 05, 2009
SOURCE: auto speaker wire diagram
FYI - I just took our 2004 Sequoia in because of speaker rattle coming from the front door speakers. Before I could tell them the problem, they guessed what it was. They see loads of Sequoias and Tundras with JBL systems due to the front door 8in speaker, basically, coming apart. His suggestion was to replace only the bottom 8in speaker, because the top tweeters usually are in good working condition. There is a minimal failure rate on the tweeters.
Posted on Mar 26, 2009
San Martian
  • 7 Answers
SOURCE: Need wiring diagram for jbl system
Go to 12Volt.com.
They have every vehicle make and model. Plus other wiring conundrums.
Posted on Jul 21, 2009
SOURCE: Have 5 JBL 125SAT speakers but no cable wires or subwoofer
have 5 jbl 125sat but without cables
what can i do?
marius
Posted on Dec 27, 2009
Turns off on its own
I have a JBL flip and according to JBL it goes into sleep if not being used for a short period, like 20 minutes... No fix according to JBL... I don't know for sure if it's the same W/Jembe...
Jan 01, 2013 | JBL Jembe Two-Piece Entertainment Speakers
MY JBL Platinum Series speakers work on one side
the first thing to establish whether its the speakers would be to try them on a different computer. If there is some sound, that means its getting some feedback. Maybe you could go to sound manager in your control panel, or on the volume menu that you can access by clicking the volume icon on your desktop taskbar, you know, by the time and stuff. Once there, adjust the balance by moving the slider all the way to either side to see if its unbalanced. You might also wanna adjust the sound scheme from mono to stereo or dolby digital which would be in the same menu/ window. Does the right speaker thats plugged into the tower have a balance (R)ight and (L)eft? you might also want to adjust that to either side. If that is not helping, maybe there is a hardware issue with the left speaker, maybe a short, or a problem with the wire and you might have to replace that speaker if you do not know how to fix speakers. Tell me how everything works out.
May 25, 2009 | HP JBL Platinum Computer Speakers
what can i do?
marius
Apr 04, 2009 | Audio Players & Recorders
I-pod connector came off
this connector is available complete with pcb from jbl service center.But radial is very difficult to open.You need to open the mesh with a hair dryer,because it is heavely glued with hot glue on the borders.you will find screws inside.And also from the bottom & sides you have to remove this decorative strip.
it is very time consuming & headache.
i have myself replaced five of this docking sockets,it will take minimum of two to three hours to do this
Oct 21, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
Just moved a set of JBL Creature Speakers...
nope not with out blowing them too spitherines
Jul 16, 2008 | JBL CREATURE II Computer Speakers
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
Acoustic
set phase to 180 put it on lfe mode turn volume a little pass half and set crosover at about 80 between 70 and 90 ok you wont go wrong set it and forget lol
Oct 06, 2007 | JBL Northridge E 250P Subwoofer
971 people viewed this question
 Grubhead
Grubhead
