Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA d52w20 Hi: Do you happen to know what the problem could be if the green light comes on and stays on for 10 seconds then goes out? It does not blink at all. Please help Thanks Mike
  • 4 more comments
  • michampagny Sep 14, 2008
    Hi:
    O.k. I checked all the capacitors I could find. I checked the rather large ones on the board where the 120 volt power comes into the t.v (power supply board?) and also the ones on the board that houses the flyback that I read on here are suspect to being trouble but they all seem to be looking good. I also checked on tops and bottoms of the boards for visual burning or loose connections but that all looks to be good too.
    Any thoughts?.
    Hey , I really appreciate you taking the time to help me with this. Thank you very much
    Mike
  • michampagny Sep 15, 2008
    Got it. I will check again but from what you are saying it looks like 99% of all problems with this particuliar set are all associated with the board that the flyback is mounted to. Is this called the deflection board? If so, I might as well just go ahead and buy the replacement board and I've got a pretty good chance of fixing this thing.
    Also, which board is the signal board?
    Thanks again for the response.
    Mike
  • michampagny Sep 16, 2008
    Hey, do you happen to know what the output voltage is supposed to be of the powerboard (the one where the power from the outlet comes into the tv.?) I checked the output and I only get 24vac?
    This seems a little low?
    Thanks
    Mike
  • michampagny Sep 17, 2008
    O.K. Just tried the capacitors. This did'nt do the trick. Same problem. The green light comes on and stays on for 10 seconds then it goes out.
    Any other ideas? What would you try next?
    Thanks
    Mike
  • Anonymous Sep 19, 2008
    My televison power light blink and now I dont have any power.
  • tlcqwhite Sep 22, 2008
    the green led light comes on then blinks then turns off
  • RCA Master
  • 8,617 Answers
That chassis has been plagued by bad capacitors on the deflection board .especially CP150 and CP114. I would suggest visibly inspecting the tops of the capacitors in the same area as those two and see if the tops look domed if so replace those capacitors. If the caps dont appear domed let me know and I will try to assist you with it.
Posted on Sep 14, 2008
  • Sonny Berry
    Sonny Berry Sep 14, 2008
    that xhassis has also been famous for solder connections around the flyback also. Its almost 100% a problem with the deflection board, Another item is the hot which is on the heat sink just above the flyback ( 2SC5588) I have seen the pins on that actually broken before. Another item has been the ribbon cblaes not seating fully between the deflection and signal board as well as the ribbon socket solder connections.
  • Sonny Berry
    Sonny Berry Sep 15, 2008
    yes that board is the deflection board with the flyback, you will have a hard time finding one at a reasonable price as they have been discontinued by RCA. The signal board is the board that is right next to that board the ribbon cables plug into the signal board. The following link has the signal board on promotional sale and I think if you send them a email they could most likely make you a deal on the deflection board as well. Heres the link, leave them a email.
    http://servicemanuals.vstore.ca/
RCA D52W20 ( power works, but no picture.)
There are four bad capacitors on the sweep board in the power supply. Pretty hard to do yourself unless you have some experience.
May 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 will not come on
sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Sep 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hdtv
Hey Lady Winn:
I tried the capacitors but nothing. It still does the same thing. The green light comes on and stays on for 10 seconds then goes out.
Thanks Mike
May 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
