Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Homelite leafa Blower Model 08010B
Wherr can I get a parts list and diagram of a Homelite leaf blower Model 08010B
  • robert bell Nov 08, 2008
    The carb seized up and broke the throttle shaft. I have two of these similar models, Seem to use the same engine and carb., The other is the "backpacker" model. Same engine, same carb. It says to try www.homelite.com or 1-800-242-4672 for parts. I'll take a look.
They also provided the address of this parts supplier:
Gardner Email Address: customerservice@gardnerinc.com Address: 3641 Interchange Road
Columbis OH 42302
614-456-4000
Posted on Nov 08, 2008
    I went to the site www.homelite.com , found the parts, and ordered online with a CC. Not bad.
    Parts probably cost more than the leaf blower, but it was given to me by a friend, so I can't kick.,
    HINT: Use the SEARCH MODEL NUMBERS link and then use 08010 and it will list the whole line. It is listed as an 08010-B model. Good Luck!
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
The piston has an little bubble that sticks out about .3 of a millimeter it wont move in the piston how do i get a new one
Not sure here what part you need, but you can check for sure here: http://www.ereplacementparts.com/
You will find parts lists and breakdown diagrams on your model. You can also purchase the part you need here.
Please vote on this solution.
Sep 10, 2010 | Homelite 30cc Piston Cylinder Kit Assy...
Primer bulb is cracked on my Homelite Blower/VAC Model HB-180 Gas is leaking, I need replacement parts. Blower purchased in 1990
www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Apr 24, 2010 | Garden
Reinstall the starter rope on a Homelite Model UT 08026 J.
Go to smalleng.com free video for just what you are experiencing.
Nov 07, 2009 | Homelite 'Yard Broom' Leaf Blower
I am looking for carb kit for my homelite leaf
Does your model #ut-08010, Have a letter after it. Homelite lists 5 or 6 models of that unit. Plus the kit they show is a complete carburetor with gasket. You will have to figure out which carburetor they put on your blower. Either a Walbro or Zama carburetor and it model to figure out which kit it will need. The homelite kit lists for about $67.00 USD.
You can go to www.precisionope.com and look it up under OEM parts.
Hope it helps.
Good Day.
Oct 20, 2009 | Homelite Garden
Homelite ht-17 magneto
Go to Gardnerinc.com and click on consumer. Then click on partsmartweb. On the left side of this page change your selection from Kohler to Homelite Consumer Products and enter your model number. You have it as HT 17. This brings up a lot of different equipment so I would enter just part of the serial number or the ut number. This is located on the body of the trimmer on a silver tag.
This will take you to the parts illustration and parts list for your trimmer.
Jun 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Atwater Strong Lit-r-blo leaf blower parts
Find model no. then go to following site
partstree.com/parts/?lc=kohler_engines&mn+Atwater+Strong+1971+-+60179D
Apr 12, 2009 | Homelite 'Yard Broom' Leaf Blower
Blower
You need to rebuild the carburetor. Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then under select OEM select Homelite then do as instructed. You should find the parts you need and hopefully the parts breakdown for the carb. this will help you in the rebuild. If it does not have the parts breakdown for the carb. find what mfg and model carb. it is then go to that site for breakdown.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
537 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
