Question about Olympus Computers & Internet
I have a vn-3100 digital recorder and just purchased the KA333 cable to transfer/backup data to pc. Not sure how to tranfer data as it di not come with instructions
    Brigadier General:
  • 7,752 Answers
Try to source it from the website
Posted on Sep 14, 2008
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
Digital Voice Recorder Vn-3100
are you sure it doesn't say "CLEAR"? Which looks like ERR on the display. Its asking if you want to "clear" all data from the recorder.
Page 9 of your manual. Here's links if you need them:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1272
http://www.olympusamerica.com/files/VN-3100_VN-3100PC_Manuall.pdf
Nov 27, 2007 | Olympus VN-3100PC Digital Voice Recorder
How do I transfer the data from digital voice recorder VN-4100PC to my PC. Thanks Elishka
check to see if the unit has a usb link cable if not you will need a cable with a plug on both ends similar to the one that a headphone has, plug this from the output on the recorder to the input on the computer (usually pink in color)and then use your favorite media software (too many to list) Good Luck!
Feb 08, 2011 | Olympus VN-4100PC Digital Voice Recorder
I recorded meeting minutes to my digital OLYMPUS VN-480 PC voice recorder and want to transfer the recording on it to my Dell Inspirion/1100 laptop. Could I transfer the audio from the headphone jack to...
yes, it is possible. You will connect the earphone jack from your voice recorder to Mic of your laptop. Then you will be needing a wave software on your laptop, download the wave software from the internet, open the wave file, then press play on your voice recorder and the minutes will be recorded into your laptop as a wave files.
But the easiest method of tranferring the minutes is by using the usb cable of your OLYMPUS VN-480 PC voice recorder. If you don't have it you can purchase it, then connect it from your OLYMPUS VN-480 PC voice recorder to the usb of your computer and it will be read like a flash drive.
After that, go to my computer and you will see a drive representing the OLYMPUS VN-480 PC voice recorder, open the drive and you will see your minutes, then simply create a folder on your computer, and copy, paste the minutes into the created folder. And the would be all.
God luck.
Oct 11, 2010 | Sony ICD-B200 Digital Voice Recorder
I can't conect my recorder to my PC
If it is a VN-1000 it is not designed to be interfaced with a computer as there is no USB port on the unit at all. If you wish to transfer the files you can purchase what is called a compaticord or patch cable that will connect through the ear jack of the recorder to the mic jack of the computer to be able to transfer the information on to your computer.
Apr 13, 2009 | Olympus VN-1000 Digital Voice Recorder
I can't transfer my files from recorder to pc
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Jan 21, 2009 | Olympus VN-3100PC Digital Voice Recorder
Deleted files and want to undelete
there is no solution... wrong type of memory for data recovery to use
Jan 14, 2009 | Olympus VN-3100PC Digital Voice Recorder
How do I connect the ka333 compaticrordto my pc to transfer what I have recorded there
connect to the mic of the computer and ear of the recorder. open up sound recorder. then play on the recorder and record in the software
Sep 22, 2008 | Olympus VN-3100PC Digital Voice Recorder
Vn-3100
use a compaticord and plug from the earphone to the mic of the pc and use sound recorder to record the message
May 16, 2008 | Olympus VN-3100PC Digital Voice Recorder
Retrieving data
No way to retrieve any erased message
Mar 17, 2008 | Olympus VN-3100PC Digital Voice Recorder
Computers & Internet Logo
53 people viewed this question
Top Olympus Computers & Internet Experts
Philip Rowney
Philip Rowney
Willem.
Willem.
Are you an Olympus Computer and Internet Expert? Answer questions, earn points and help others
