Question about Toshiba Televison & Video
S-vedio output connected with TV does not give any sound. Is the S-vedio output connection with a TV not enough for sounds?
Right, S-Video is higher quality video only, sound still goes out through 'red'/'white' RCA phono plugs near the other (lower quality) 'yellow' video out
Posted on Sep 14, 2008
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Tip
How to connect external tv box to your pc ?
simply <br /> <br /> 1- vedio connection<br /> <br /> connect the monitor data cable to the the external tv box and take the out data cable from external tv <br /> <br /> connect to your pc <br /> <br /> 2- sound connection <br /> <br /> take sound cable from tv sound out to line in pc ( don't forget to open line in , in the sound properties )<br /> <br /> 3- finally connect the the adaptor to the tv box and play all <br /> <br /> best regards <br />
on Apr 02, 2011 | Computers & Internet
How do i connect my soundbar to my technika lcd 32-244 tv
There should be a output on the TV. Hook the sound bar up, set the TV up to use external sound and use the sound bar remote untill you sync it to a different remote. Give it a try!!!!
May 22, 2014 | Televison & Video
How to connect a sabrent external tv tuner box
simply
1- vedio connection
connect to your pc
2- sound connection
best regards
if you see that is helpful plz dont forget to vote me
Change video output to s vedio connection
If the computer does not easily and automatically show the computer screen on the tv through the S-video output, make sure the tv is switched to S-Video and Hold down the Fn + F5 keys to toggle through the video output manually on the laptop. Just make sure that only one video source is connected at a time. Your laptop will not support two output sources at the same time. Below is the user manual in which it discusses the use of an external device on page 70.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2059997&rpn=PSPC0U&modelFilter=P305-S8832&selCategory=3&selFamily=1073768663
Oct 31, 2009 | Toshiba Satellite P305D-S8834 Notebook
Bad cable input connector?
try use vedio input for work....or use vcr ant in vcr vedio output to tv...
no need replaced tv
Aug 13, 2009 | Televison & Video
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
No sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
Sep 13, 2008 | Audio Players & Recorders
No sound from tv to surrond sound.
First, press the SURR button to see if you can get sound out of more than 2 speakers, then:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Dec 28, 2007 | Philips HTS-3555 System
No surround sound for TV
-Tha Mp3 Doctor
Nov 18, 2007 | Philips HTS3400/37B System
Televison & Video Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
