Question about Hoover Vacuums
Hoover shampooer. model f5906-900 series 12.0 brushes on bottom won't turn.
  • 126 Answers
SOURCE: brushes
This machine has no belts. There is an air driven turbine that propels the brushes. If you look under the little glass window at the left front corner of the machine, there is an intake screen just above the indicator dial. That screen is there to keep debris from entering the turbine and will have to be kept clean. If it is clogged, then the turbine will not function.It is also possible that moisture has entered the turbine and siezed the bearings. If that is the case, the turbine would have to be replaced. Also, because this turbine works off the suction of the motor, if the recovery tank lid is not on correctly, then the suction loss will effect the brushes. Check the lid and make sure it is on right.
Posted on Jan 13, 2008
  • 3 Answers
SOURCE: hoover F7431-900
If the screen is not dirty, and the flapper valve to the turbine inlet is open, then the problem is mostly a stuck turbine impeller. The turbine impeller on my F7431-900 has seized TWICE!! The shaft for the turbine is not made of stainless steel, therefore is subject to corrosion. If you have a handy husband or boyfriend, give it to them, because some disassembly is required to access the turbine unit. After the turbine is removed and opened up, get some P'Blaster and squirt is on the shaft. P'Blaster is a rust removing solvent and is great for freeing up rusty nuts and bolts. Allow the P'Blaster 20-30 minutes to penetrate the corroded shaft. Then, grab the impeller and wiggle it back and forth, until free rotation is achieve. The last time my brushes stopped rotating, and I disassembled the turbine, it was really siezed up. I thought I was going to need to buy a new impeller assembly. But, that P'Blaster is really great stuff for breaking up corroded parts (it's like WD-40 on steroids!). I did need to give the turbine's impeller a good twist to free it up. If you can't get the turbine impeller to rotate, then buy a new one (about $27.00). Then, you can just install it and save a bundle on labor. I think I want to become a Hoover vacuum repairman. Their business must be booming because Hoover is putting out a poorly designed turbine unit. Boo, Hiss...... shame on Hoover for selling us **** like this.
PS You can get P'Blaster at any auto store, like Pep Boys, Autozone, etc.
Posted on Aug 28, 2008
SOURCE: i got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Posted on Dec 28, 2008
  • 294 Answers
SOURCE: where can i get a replacement water tank? for
The replacement parts can be ordered from hoover or through any hoover dealer. thier info can be found through the Hoover website. If you are unable to obtain a direct match, there may be available ones in different color.
Posted on Oct 25, 2009
  • 175 Answers
SOURCE: the brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Posted on Nov 28, 2009
Brushes on bottom of hoover rug cleaner not spinning
The most common reason for this is that the air driven turbine has failed. To test it, insert a screwdriver into the square hole that the brush pin normally fits into and see if it turns. If it does not turn, the turbine assembly will need to be replaced. To prevent failure in the future, always store the shampooer with the upper tank removed, and squeeze the trigger to thoroughly empty the soap solution from the machine.
Jun 07, 2011 | Hoover Vacuums
The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Jan 03, 2010 | Hoover V2 U8140-900 WindTunnel Upright...
The brush won't spin on my hoover shampooer
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes wont spin on my Hoover rug shampooer Model # f7220-950.
try cleaning brush...
if sam problem need replaced turbine part no: 43191009 Turbine & Gear Assem
Nov 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hoover carpet shampooer not working
I need new brushes! Also the only thing not working on my Shampooer is the brushes are not rotating, where can I get it fixed.
Thank You
Manny Romero
1-760-246-2001 or gpamanny@hotmail.com
May 01, 2008 | Vacuums
Vacuums Logo
73 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
