Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
Kenmore 116 29412990 canister
I wanted to know how to get to the cord.It is a retractable type. Thanks in advance. John
  • cooperco Sep 20, 2008
    I would love to know the answer to this as well and I too thank you in advance.
  • Anonymous Jan 25, 2009
    same problem here too! I can't get to the cord wheel housing
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I am wanting to know how to remove the power cord wheel assembly. I ordered an entire new assembly and I am trying to replace it.
HI smarger,
First, remove the hood and tool compartment covers. At each corner of the cover, by the cord retract button, is a screw. Remove these two screws. Pull the button off. It is difficult to remove but just keep pulling until it's out.
Under the button there are 2 more screws. Remove these and you can take off the cover to expose the cord reel.
There are 2 screws on the back of the bracket that hold the reel onto the bracket.
Good luck.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 25, 2011 | Kenmore 23812 Progressive PowerMate Bagged...
Dear Technician, I have a problem with my cord to retract back in the canister vac. Would you please help with this problem solution. ...
Try tilting the vacuum so the front is at about a 75-90 degree angle to the back. Gently tug and release cord. This will usually retract the cord.
Jan 20, 2011 | Electrolux Lux 5500 Canister Vacuum
Cord retraction help
if you can open it up extend the cord and wrap it around the spool.make sure its clean.spray a little wd40 on the shaft of the pully so it moves freely
Apr 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Sanyo vacum cleaner SC-815
The power cord does not stop and retracts automatically, how do I re-tension the cord,
Do you have copy of instruction manual or manual on repair?
Apr 19, 2008 | Sanyo SC-800P Bagged Canister Vacuum
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
63 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
