Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Bad noise when the tv is turned on it makes a noise like barrings are going out, tv repairman said the color wheel was going out and needed to be replaced he has had the tv over a month now and said parts are on back order, if the color wheel was going out wouldnt i have a bad picture (in which i did not)
  • txsweetheart Sep 14, 2008
    Thank you so much for your advice, he told me it was going to be around 400. to fix it, and as far as removing the tv from the home it was the better solution for the both of us, as i had bought a larger tv for the room and having to remodel the entertainment center in the game room for the 50" it just made better sense for him to take it instead of trying to store it untill the work was finhised on the room.
    Novelist:
    Champion:
  • 203 Answers
Nope, sometimes you can have a perfect picture and the color wheel can still be bad squealing like a lawnmower. However if your model number is HLN5065w, then you may want to have him look around for the part. One of my suppliers has it in stock and one it is on back-order, so if he looks around he might be able to find one. You also threw a red flag up when you said that he has your tv, I prefer to never remove a tv from a home in order to do a repair and hope that most other shops do as well. Please let me know how much he is charging you so i can make sure that its a good rate and your not getting ripped off! Let me know so i can help!
Tim Nolan
Posted on Sep 14, 2008
  • experttv
    experttv Sep 14, 2008
    $400 is a good price, down here that would be more like $500 hope he finds that part for you soon, if he cannot let me know i might be able to point him in the right direction.
    Tim Nolan
Philips tv 50pl9126d/37 help
Hello your problem is you have a bad color wheel that needs replacing.
Nov 09, 2011 | Philips 50PL9126D/37B 50" DLP TV
My Sony wega KDF e55a20 makes a weird sound when I turn it on and it keeps making it until I turn it offp
Since it is a DLP then you have a bad color wheel making the noise. Changing it requires skilled technical knowledge and not recommended for the average person. I suggest calling your local tv repairman to do the job correctly.
Jul 25, 2011 | Televison & Video
Buzzing noise from back of television
Ur tv colors wheel is going to die soon.U lose colors,tv turn into black and white.It make buzzing,squiling and ratterling noises.The colors wheel is spinning off of it axis,it dead.Require changing the colors wheel.Call the tv repairman to do this job.Must take out many machanical parts even to get to the colors wheel to change it.Never done this before don't atemp this to do this ur self.Tv tech.well charge u more,if he have fix ur blunders.
May 08, 2010 | Samsung DLP HL-P5663W 56" TV
Loud buzzing noise and no color. Does this mean the color wheel is bad. Thanks
Yes,the colors wheel is worn out,U have no machanical skills,hire a tv repairman to change this.Require take out many parts before can even to get to the colors wheel,to replaced.
Mar 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
The fan intermittenly makes a noise and the color changes on the tv
You need to give model #. Most likely you have a dlp tv and its not the fan but the color wheel that spins at very high speed and creates correct colors on your screen. This color wheel makes noise when its bad and colors go off when its running at slower speeds. Its going to fail sooner or later as its going bad now. Its a professional job to change the color wheel and could cost you $280-320 depending on the model. Fan generally never make anoise that is loud enoug to be heard unless its blades are hitting some obstru ction. Color wheels make whining or in worst case screeching noise when bad. check out www.fixurtvs.com for more FAQs. Thanks if you voted for me.
Mar 21, 2010 | Televison & Video
My tv, just shut off! the screen does not turn on, and makes a squealing noise! what is wrong?
That is the classic case of the color wheel going out on you. The color wheel has ball barrings that tend to break and cause friction within the wheel. It'll start squealing loudly when it becomes stuck. Before it broke, did you notice the color going out or a fuzzy picture with poor skin tones? That's the color wheel!
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Can you help me with my TV problem???
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. Your TV may have a new type color wheel assy that has a slightly different configuration but the result is the same.
michtech
Oct 12, 2008 | Mitsubishi WD-73732 73" Television
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
