Question about Maytag PYE2300AY Electric Dryer
Kenmore dryer stopped working, start button does nothing
The dryer was working fine then in the middle of a load it stopped working. I pressed the start button and it worked for about 10 seconds. Now when you push the start button there is nothing. Power is fine. I replaced the start button but still the same. Timer is counting down fine. The drum moves fine. The starter must trip a relay. Where is the relay? The orange wires run down the back and the schematic diagram doesn't have colors on the wires. My Maytag just done the same thing.. quit working in the middle of drying a load of clothes. No signs of any problem. I checked my breakers..no problem there. There's no power at all when I push the button. What could be wrong with it and is it something I can fix?
  • sharon1226 Nov 22, 2008
    My maytag dryer suddenly quit working after I cleaned the lint trap. The dryer in less than two years old. It is a gas dryer. I need help and can't afford a repair man.
  • 943 Answers
Hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Posted on Sep 16, 2008
My Sears Kenmore Elite dryer stopped working in the middle of a drying cycle. The drum light is still works - so it has power. But when I press the Start button, I just hear a faint clicking sound. Any...
Most common cause is a partially or fully clogged dryer exhaust vent makes the dryer overheat and trips the high temp limit fuse. Brush out the vent all the way to the outside.
Feb 20, 2011 | Kenmore Dryers
I have a Kenmore 400 series top loading electric dryer that just stopped working right in the middle of a load of clothes. It was working just fine and then it just stopped. Now it will not turn on at...
Hi there....this sounds to be like you blew the breaker. Go to your breaker panel in your house and search out the fuse for the dryer. This will be a double 110 volt breaker. You need to reset both sides to be sure. It is easily locatable as they almost always have the items listed on the inside of the door of the panel. If this works for you great. Please try to remember to click on the yes box on your way out ...thank you and good luck.
Oct 10, 2010 | Kenmore 73952 Gas Dryer
Our dryer stopped working in the middle of a load. Now when I press the start button the timer does nothing but click. I am not sure but I thought it might be the push start button was faulty. Any ideas?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | Kenmore 64892 Electric Dryer
My Dryer just stopped working in the missle of a
with your door open have some one try and turn the dryer on while you hold the button in and turn the drum by hand to get it started.
if it starts the your motor may just have lint build up around it causing the contacts to be dirty.
there is a couple of other things that might have gone wrong the main control board has gone bad or the door switch, motor has gone out
Jan 30, 2010 | Kenmore Elite HE4 Electric Dryer
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Electric dryer
Disconnect the power cable, remove dryer's cover and look for a loose wire.
Mar 26, 2007 | Magic Chef CYE4000AWW Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
296 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
