Question about Lands Phones
Busy signals on all handsets, cannot call or recieve calls
  • 4 more comments
  • ronaldandpat Sep 13, 2008
    I DON'T SEE A SOLUTION FOR THIS PROBLEM.
  • ronaldandpat Sep 14, 2008
    THESE ARE LANDLINE PHONES, MY PROVIDER IS VONAGE
    NOTHING IS ON MY MESSAGE PHONE
    SUGGESTION DID NOT FIX PROBLEM
    DID NOT FIX THE PROBLEM.
    DID NOT FIX THE PROBLEM, IS IT POSSIBLE THAT OUR LAST CALLER DID NOT HANG UP?
    Sergeant:
  • 241 Answers
There may be a few problems here
  • check to make sure there are no there phone that cordless and are dead
  • place all back on the charger
  • unhook all phones and use a LAN line phone
  • plug it into every one of the jacks in the house
  • try to see if you are getting a busy sound from all of wall jacks
  • go ouside or in the bestment find the phone box that comes in to the house and make
           sure that all the connections are on the terminal
  • If you have more that 1 phone line there then one of the phone jacks coming from the wall may
          have came lose. Just remove the wall jack cover and make sure that all the wires are
connected.
Note if you only have one phone line then there shouild only be 2 wires on the phone jack connecteed
this usally green and red but it can be diferent depending on how it is wired.The wires have a low current so unless your phone rings while you are touching them you will not feel anything (it is a small zap but safe if the phone happens to ring)
Thank You
Jayson
Posted on Sep 14, 2008
  • Jayson Brollini
    Jayson Brollini Sep 14, 2008
    No that s not the case just look at the other posted solutions
    thank you
  • Jayson Brollini
    Jayson
    Brigadier General:
  • 6,966 Answers
Assuming that the system/set-up has worked before and initially, pls try to:
  • determine if you have Internet access;
  • reset your modem (backup config);
  • reset your router (backup config);
  • check port forwarding requirement and/or router settings.
If this is a new set-up:
  • pls post back your modem and/or router brand & model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 10,594 Answers
If you asked for line phone sets, then..Please disconnect all handsets and let rest phone line once, now connect handsets one by one and confirm which one is bad or hold phone line so you get busy line tone.
If you are talking about cordless phones, power off base unit and let phone line reset. now power up it and check handsets one by one.
  • Shahid Electronics
    Shahid Electronics Sep 14, 2008
    Yes, its possible that last caller didn't hang up, in this case you ask help from phone provider.
  • 958 Answers
You may have a problem with your telephone lines.
use another known working phone a hook it up to your telephone line and if you still have a busy signal then it is in your phone.
if you do have a dial tone and you can use the phone that you just hook up, then the problem is in your phone.
hook again the problematic phone and you can use it the first time and after you hang up, busy tone appears, then you can not call nor receive calls.
the problem is in the phone, there is a transistor that supposed to disconnect the line after use but it won't.
i have encounter one unit before.
tnx 4 using fixya,
drcool
  • 56 Answers
Do you have any messages in your memory bank? check and make sure they are all read or deleted.... this may seem to cause this problem....
    Sergeant:
  • 264 Answers
Are you refering to a cellphone or a landline phone
  • Sameer Kashyap Sep 14, 2008
    Have you subscribed for the voice mail. If your voice mail with the provider(vonage) is full, you may have this issue.
    No if the last caller does not hang up the call is suppose to get disconnected within 2 minutes. It must be a bad line. You must get a free line test done by the service provider. They have equipments to do the same and can do it sitting in their office itself.
Constant busy signal
Has this constant busy signal just started or has it come recently? If you've got a space receiver/handset use it to replace what you've got connected at present. If fault persists then it's not the unit that's at fault but the line's faulty and needs reporting to the service provider. If the fault went away when you changed the unit then you know that the problem lies with the handset/receiver or whatever you call it. Decide what to do in this case-probably get a better handset.
May 06, 2015 | Lands Phones
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
I have the DECT1580 cordless phone with 4 handsets. Lately, people cannot hear me when I call them. Sometimes it cuts in and out. It's happening with more than one of the handsets. Help.
Weak or Hard to Hear Audio (From the Uniden Manual)
If the caller’s voice sounds weak or soft, the signal might be blocked by large metal objects or walls; you might also
be too far from the base, or the handset’s battery may be weak.
  1. Try adjusting the volume of the earpiece (see page 36) or the audio tone
  2. Try moving around while you’re on a call or moving closer to the base to see if the sound gets louder.
  3. Make sure the handset’s battery is fully charged.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
No dial tone/ others trying to call get busy signal
there is no problem with your phone.Because the main problem is the simcard you are using...try to buy a new simcard
Jun 20, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
All 4 handsets note "busy" and there is a sound like a busy signal. What gives
CLICK HERE for your owners manual in PDF format.
CLICK HERE for the troubleshooting section.
"BUSY" in the display means -
*The called handset is in use.
*The handset you are calling is too far from the base unit.
*There is no handset registered to the base unit matching the extension number you entered.
*Other units are in use and the system is busy. Try again later.
Remove the batteries form each handset.
Replace them one at a time and check for proper operation.
One may have become unregistered when a battery died - or power outage.
See page 35 of the manual to un-register and re-register them to the base.
Thanks for using FixYa - if you require further clarification, please use the "Continue With This Expert" option so we are connected in the future.
Thank You :D
May 13, 2009 | Panasonic KX-TG1033S Cordless Phone
I cannot use my phones since Saturday. The phone message on hand
try to perform a soft reset.
Using:
menu/settings/ restore factory settings.
Dec 22, 2008 | Uniden Cordless Phone
Can't recieve a fax.
Unplug power cord. Plug back in. Call your fax machine from cell phone and listen for fax tones.
Sep 17, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
Callers are getting a busy signal when my phone is not in use.
sounds to me that the phone set is shorted when you pick up the reciever it shorts the line but if the phone is already shorted this is why people are getting the busy signal
Aug 07, 2008 | Lands Phones
Lands Phones Logo
137 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
