Initial IDM-1210 Portable DVD Player with Screen
Problem for Initial IDM-1210 Portable DVD Player with Screen
Dvd not loading
By msacl on May 28, 2006
When I insert any dvd into the dvd player I get a 'Loading' message on the screen, but the dvds never load. While trying to load, the dvd player is making a noise. At first I thought that the dvd wasn't spinning and that that is where the noise was coming from, but it's spinning when I go to remove the dvd. It seems like the dvd player just insn't reading/loading anything.
Same Problem
May 04, 2009
-   I have the exact same DVD player Initial IDM-1210, and I have the exact same problem.-   Charlie130
Mar 29, 2009
-   I have the exact same problem with even finding a disc to clean my portable DVD (that one worked) and trying several discs with nothing but LOADING showing up on the screen. I am the only one that uses this, never dropped, never wet and usually in case when I travel. If someone has a solution that would be great!! Thank you.-   rkalaska
Solution #1
posted on May 31, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3613 votes
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens.
This is assuming you get this with all disks, otherwise better not risk opening it.
Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved.
Anything else is for the lab(motor, lens assembly, focusing problems etc)
Good luck
Comments:
May 31, 2006
- Fixed one 3 days ago, just that. Both DVD players in my house have been through the same thing, one of them twice.
May 31, 2006
- Sorry, I missed the fact that it's a portable. More chances that it's the other stuff then(motor, lens assembly, focusing problems etc)
Was this helpful?
Yes
No
Popular Solutions for Initial IDM-1210 Portable DVD
Questions and Unsolved Problems for Initial IDM-1210 Portable DVD
Do you recommend Initial IDM-1210 Portable DVD Player with Screen?
Answer
Answer
program guide not working since digital reshuffle 2nd Dec. All channels receiving fine, machine... (More)
Answer
It says "no disk" when dvd is in. Lens is clean too.
Answer
I have a Initial portable dvd player IDM - 1210. when I play a dvd it will play the prevews but if I... (More)
Answer
whenever i put a dvd in the screeen says no disk and the dvd is properly inserted
Answer
When I open the screen , it lights up normally , but within minutes it starts to get fuzzy , and all... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
