Question about JVC Televison & Video
I am trying to hook up an HD / DVR and my cable serice to a JVC AV2730 TV The TV ony has RF connector (none from HD/DVR box), S-video connector, and Video Component/Y Pb Pr hookups. Which ones do I use? My other TV has Video and Audio L/R, this TV does not.
Well first off i am assuming that your jvc ONLY has rf connections?
if so, the most you can do is go get an adaptor from walmart that has inputs for either svideo or components and output for rf.
Posted on Sep 13, 2008
I have an HDMI hooked up from the back of my DVR box to my JVC, but the picture still doesnt look as clear as it should.. Would it have to do with how my settings are programmed? If so, how should my...
Check ur DVR box setting make sure is on HDMI cable setting mode or HD setting mode.The picture will be in HD setting and the picture will be coming into tv clearly.
Apr 21, 2011 | JVC LT42P789 42 in. LCD TV
When hooked directly to cable, I get a blue screen and sound. When hooked to Componet Video, S- Video, or Composit Video via a cable box, I get a picture and sound. Apex remote will not change sound or...
your cable box rf pass through may be turned off if you can access the menu of the cable box by turning it off and hittiing th emenu button on the cable box with tv on an scroll down to rf out if you need hael call your local cable company
Nov 19, 2009 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Can an adapter be used to connect this unit to a sony hd ready tv. The sony has the round connector for hook up and not the square type. I want to hook up a DCT 3400 Series High-Definition DVR
If your Sony TV is hd ready you have a number of choices of connections you can use. On the back of the DCT 3400 you have regular AUDIO and VIDEO connections, the separate Y, Pb, & Pr connections (both of these use the regular RCA style connectors), RF in (which uses the standard cable connection), and the HDMI connector, which uses a special flat ribbon style connector. Your Sony should have all of these types of connectors on the back of the TV. The separate Y, Pb, & Pr, or HDMI connectors will give you the best picture.
Aug 08, 2009 | Televison & Video
60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Hd dvr
if you are connecting the dvr via component video cables select the output to 480i and not 480p or other higher formats.the tv cannot support anything higher than 480i. or try using composite video hookup instead.
Jan 29, 2008 | JVC AV-36320 36" TV
Trying to connect my xbox
hook it up in place of the cable box...rf adapter or use the rca plugs and get barrel adapters to connect them
Oct 30, 2007 | Microsoft Xbox Console
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Televison & Video Logo
70 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
